[MOAB-dev] [PATCH 2/2] libiGeomMOAB Needs to link libiMesh
    Jed Brown
    jed at 59A2.org
    Fri Jun 10 07:53:14 CDT 2011
On Fri, Jun 10, 2011 at 14:45, Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
> We may have problems, that iGeom_MOAB implementation is not well maintained
> now.
> I need to change it to use FBEngine
> I am not sure about other applications, which may need iGeom implemented in
> CGM.
> Using FBEngine directly might not be an option for you (it is not iGeom)
I'm not even depending on it for anything significant, but I set up the
build system to build this stuff and installing a library that doesn't link
properly is no good. Most of my stuff doesn't even call iGeom at all. But
I'd rather not have to change the build system to recover gracefully if
iGeom "exists", but is not being linkable due to undefined symbols.
So why not either turn it off completely (don't compile it/don't install it)
or make it linkable?
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110610/16a0e1d3/attachment.htm>
