[MOAB-dev] r4983 - in MOAB/trunk: MeshFiles/unittest src src/moab test
iulian at mcs.anl.gov iulian at mcs.anl.gov
Thu Jun 9 12:29:55 CDT 2011
Author: iulian
Date: 2011-06-09 12:29:55 -0500 (Thu, 09 Jun 2011)
New Revision: 4983
Added:
   MOAB/trunk/MeshFiles/unittest/BedCrop2.h5m
   MOAB/trunk/MeshFiles/unittest/SECrop2.h5m
   MOAB/trunk/MeshFiles/unittest/poly14.txt
   MOAB/trunk/test/crop_vol_test.cpp
Modified:
   MOAB/trunk/MeshFiles/unittest/Makefile.am
   MOAB/trunk/src/FBEngine.cpp
   MOAB/trunk/src/GeomTopoTool.cpp
   MOAB/trunk/src/moab/FBEngine.hpp
   MOAB/trunk/src/moab/GeomTopoTool.hpp
   MOAB/trunk/test/Makefile.am
   MOAB/trunk/test/gttool_test.cpp
   MOAB/trunk/test/mbfacet_test.cpp
Log:
first pass at creating volumes in mesh-based geometry
fix (another) bug in splitting surfaces. it is probably the zillionth
the separate method should be improved in the advancing front part (it is
too slow)
the lifecycle of smooth surfaces / edges should be fixed
Any time a splitting/cropping operation is involved, the smoothing needs
to be fixed/recomputed.
some reordering/compacting would help too
Added: MOAB/trunk/MeshFiles/unittest/BedCrop2.h5m
(Binary files differ)
Property changes on: MOAB/trunk/MeshFiles/unittest/BedCrop2.h5m
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: MOAB/trunk/MeshFiles/unittest/Makefile.am
--- MOAB/trunk/MeshFiles/unittest/Makefile.am	2011-06-09 17:11:24 UTC (rev 4982)
+++ MOAB/trunk/MeshFiles/unittest/Makefile.am	2011-06-09 17:29:55 UTC (rev 4983)
@@ -24,5 +24,8 @@
               partBed.smf \
               PB.h5m  \
               polyPB.txt \
-              quads.h5m
+              quads.h5m \
+              SECrop2.h5m \
+              poly14.txt \
+              BedCrop2.h5m
Added: MOAB/trunk/MeshFiles/unittest/SECrop2.h5m
Property changes on: MOAB/trunk/MeshFiles/unittest/SECrop2.h5m
Added: MOAB/trunk/MeshFiles/unittest/poly14.txt
--- MOAB/trunk/MeshFiles/unittest/poly14.txt	                        (rev 0)
+++ MOAB/trunk/MeshFiles/unittest/poly14.txt	2011-06-09 17:29:55 UTC (rev 4983)
@@ -0,0 +1,5 @@
+0. 0. 1. 22
+573021 7.66647e+06 -2000
+588480 7.6749e+06 -2000
+587072 7.67655e+06 -2000
+572575 7.67171e+06 -2000
Modified: MOAB/trunk/src/FBEngine.cpp
--- MOAB/trunk/src/FBEngine.cpp	2011-06-09 17:11:24 UTC (rev 4982)
+++ MOAB/trunk/src/FBEngine.cpp	2011-06-09 17:29:55 UTC (rev 4983)
@@ -411,9 +411,11 @@
