[MOAB-dev] r4980 - MOAB/trunk/config
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu Jun 9 11:51:52 CDT 2011
Author: kraftche
Date: 2011-06-09 11:51:52 -0500 (Thu, 09 Jun 2011)
New Revision: 4980
Modified:
   MOAB/trunk/config/compiler.m4
Log:
fix bugs in previous checkin
Modified: MOAB/trunk/config/compiler.m4
--- MOAB/trunk/config/compiler.m4	2011-06-09 16:39:10 UTC (rev 4979)
+++ MOAB/trunk/config/compiler.m4	2011-06-09 16:51:52 UTC (rev 4980)
@@ -308,7 +308,7 @@
   cxx_compiler=unknown
   case "$target_os" in
     aix*)
-      FATHOM_TRY_COMPILER_DEFINE_GE([__IMBCPP__],[800],[cxx_compiler=VisualAge8],
+      FATHOM_TRY_COMPILER_DEFINE_GE([__IBMCPP__],[800],[cxx_compiler=VisualAge8],
         [FATHOM_TRY_COMPILER_DEFINE([__IBMCPP__],[cxx_compiler=VisualAge])])
     solaris*|sunos*)
@@ -319,7 +319,8 @@
     linux*)
       FATHOM_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cxx_compiler=Intel])
-      FATHOM_TRY_COMPILER_DEFINE([__IBMCPP__],[cxx_compiler=VisualAge])
+        [FATHOM_TRY_COMPILER_DEFINE([__IBMCPP__],[cxx_compiler=VisualAge])])
       FATHOM_TRY_COMPILER_DEFINE([__DECCXX_VER],[cxx_compiler=Compaq])
       FATHOM_TRY_COMPILER_DEFINE([__SUNPRO_CC],[cxx_compiler=SunWorkshop])
       FATHOM_TRY_COMPILER_DEFINE([__PGI],[cxx_compiler=PortlandGroup])
@@ -384,13 +385,11 @@
     FATHOM_CXX_SPECIAL="-qrtti=all"
     AR="ar -X 32_64"
     NM="nm -B -X 32_64"
-    esac
   VisualAge8:*)
     FATHOM_CXX_32BIT=-q32
     FATHOM_CXX_64BIT=-q64
     NM="nm -B -X 32_64"
-    esac
   MIPSpro:mips)
     FATHOM_CXX_32BIT=-n32
