[MOAB-dev] r4978 - in MOAB/trunk/src: . moab
kraftche at cae.wisc.edu
Thu Jun 9 11:20:36 CDT 2011
Author: kraftche
Date: 2011-06-09 11:20:36 -0500 (Thu, 09 Jun 2011)
New Revision: 4978
Modified:
MOAB/trunk/src/OrientedBoxTreeTool.cpp
MOAB/trunk/src/moab/OrientedBoxTreeTool.hpp
Log:
back out accidental checkin
Modified: MOAB/trunk/src/OrientedBoxTreeTool.cpp
--- MOAB/trunk/src/OrientedBoxTreeTool.cpp 2011-06-09 16:13:35 UTC (rev 4977)
+++ MOAB/trunk/src/OrientedBoxTreeTool.cpp 2011-06-09 16:20:36 UTC (rev 4978)
@@ -32,7 +32,6 @@
#include <limits>
#include <assert.h>
#include <math.h>
-#include <float.h>
//#define MB_OBB_USE_VECTOR_QUERIES
//#define MB_OBB_USE_TYPE_QUERIES
@@ -219,8 +218,6 @@
max_depth( 0 ),
worst_split_ratio( 0.95 ),
best_split_ratio( 0.4 ),
- always_use_element_side_splits(false),
- num_element_for_side_splits(5),
set_options( MESHSET_SET )
@@ -231,7 +228,6 @@
&& worst_split_ratio <= 1.0
&& best_split_ratio >= 0.0
&& worst_split_ratio >= best_split_ratio
- && num_element_for_side_splits > 0
@@ -338,16 +334,16 @@
*\param num_intersecting Output, number entities intersecting plane
static ErrorCode split_box( Interface* instance,
- const CartVect& normal,
- const CartVect& point,
- const Range& entities,
- Range& left_list,
- Range& right_list )
+ const OrientedBox& box,
+ int axis,
+ const Range& entities,
+ Range& left_list,
+ Range& right_list )
ErrorCode rval;
left_list.clear();
right_list.clear();
std::vector<CartVect> coords;
for (Range::reverse_iterator i = entities.rbegin(); i != entities.rend(); ++i) {
