[MOAB-dev] r4966 - MOAB/trunk/src/moab
kraftche at cae.wisc.edu
Wed Jun 8 09:57:43 CDT 2011
Author: kraftche
Date: 2011-06-08 09:57:41 -0500 (Wed, 08 Jun 2011)
New Revision: 4966
Modified:
MOAB/trunk/src/moab/Interface.hpp
Log:
add more documentation for new tag_get_handle function
Modified: MOAB/trunk/src/moab/Interface.hpp
--- MOAB/trunk/src/moab/Interface.hpp 2011-06-08 14:24:27 UTC (rev 4965)
+++ MOAB/trunk/src/moab/Interface.hpp 2011-06-08 14:57:41 UTC (rev 4966)
@@ -1153,7 +1153,7 @@
* default value if one is specified and is otherwise ignored.
*\param type The type of the data (used for IO)
*\param tag_handle Output: the resulting tag handle.
- *\param flags Bitwise OR of values from \c TagType
+ *\param flags Bitwise OR of values from TagType
*\param default_value Optional default value for tag.
*\param created Optional returned boolean indicating that the
* was created.
@@ -1164,6 +1164,49 @@
* - \c MB_TYPE_OUT_OF_RANGE invalid or inconsistent parameter
* - \c MB_VARIABLE_DATA_LENGTH if \c MB_TAG_VARLEN and \c default_value is non-null and
* \c default_value_size is not specified.
+ *\NOTE A call to tag_get_handle that includes a default value will fail
+ * if the tag already exists with a different default value. A call without
+ * a default value will succeed if the tag already exists, regardless of
+ * whether or not the existing tag has a default value.
+ * Examples:
+ * Retreive a handle for an existing tag, returning a non-success error
+ * code if the tag does not exist or does not store 1 integer value per
+ * entity:
+ *\code
+ * Tag git_tag;
+ * mb.tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, gid_tag );
+ * \endcode
+ * Get the tag handle, or create it as a dense tag if it does not already
+ * exist:
+ *\code
+ * Tag gid_tag;
+ * mb.tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, gid_tag, MB_TAG_CREAT|MB_TAG_BIT );
+ * \endcode
+ * Create the tag or *fail* if it already exists:
+ *\code
+ * Tag gid_tag;
+ * mb.tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, gid_tag, MB_TAG_EXCL|MB_TAG_DENSE );
+ * \endcode
+ * Get an existing variable length tag, failing if it does not exist or
+ * is not variable-length or does not contain double values.
+ *\code
+ * Tag vtag;
+ * mb.tag_get_handle( tag_name, 0, MB_TYPE_DOUBLE, vtag );
+ * \endcode
+ * Get the same variable-length tag, but create it with a default value
+ * if it doesn't exist. Note that if the tag already exists this call
