[MOAB-dev] r4945 - in MOAB/trunk: MeshFiles/unittest test
iulian at mcs.anl.gov iulian at mcs.anl.gov
Sat Jun 4 08:49:07 CDT 2011
Author: iulian
Date: 2011-06-04 08:49:02 -0500 (Sat, 04 Jun 2011)
New Revision: 4945
Modified:
   MOAB/trunk/MeshFiles/unittest/Makefile.am
   MOAB/trunk/test/mbfacet_test.cpp
Log:
distcheck failed because the test files were not part of distribution.
also, we can't create new files there during test, they must be created
(and deleted) in the working directory.
Modified: MOAB/trunk/MeshFiles/unittest/Makefile.am
--- MOAB/trunk/MeshFiles/unittest/Makefile.am	2011-06-03 20:23:07 UTC (rev 4944)
+++ MOAB/trunk/MeshFiles/unittest/Makefile.am	2011-06-04 13:49:02 UTC (rev 4945)
@@ -20,5 +20,9 @@
               testquad.g \
               testtet.g \
 	      ptest.cub \
-              64bricks_512hex.h5m
+              64bricks_512hex.h5m \
+              partBed.smf \
+              PB.h5m  \
+              polyPB.txt \
+              quads.h5m
Modified: MOAB/trunk/test/mbfacet_test.cpp
--- MOAB/trunk/test/mbfacet_test.cpp	2011-06-03 20:23:07 UTC (rev 4944)
+++ MOAB/trunk/test/mbfacet_test.cpp	2011-06-04 13:49:02 UTC (rev 4945)
@@ -743,7 +743,7 @@
   // export split triangles model, after deleting the smooth tags
   pFacet->delete_smooth_tags();
-  std::string spl_file=quads_file+".split.h5m";
+  std::string spl_file="q.split.h5m";
   rval = mb->write_file(spl_file.c_str(), 0, 0, &root_set, 1);
   CHECK("can't write result file");
