[MOAB-dev] Fwd: r4943 - in MOAB/trunk: MeshFiles/unittest/io src/io test/io
Tim Tautges tautges at mcs.anl.gov
Fri Jun 3 15:22:27 CDT 2011
Yep, sorry, last-minute untested change, very bad.  Will commit a fix momentarily.
- tim
On 06/03/2011 03:18 PM, Iulian Grindeanu wrote:
> I get some compiling errors, even after make clean.
>    CXX    ReadNCDF.lo
>    CXX    WriteNCDF.lo
>    CXX    WriteSLAC.lo
>    CXX    ReadNC.lo
> ReadNC.cpp: In member function ‘moab::ErrorCode moab::ReadNC::create_tags(const std::vector<int, std::allocator<int>  >&)’:
> ReadNC.cpp:1183: error: ‘MB_TAG_CREATE’ was not declared in this scope
> ReadNC.cpp:1205: warning: ‘moab::ErrorCode moab::Interface::tag_create_variable_length(const char*, moab::TagType, moab::DataType, moab::TagInfo*&, const void*, int)’ is deprecated (declared at ../../src/moab/Interface.hpp:1252)
> ReadNC.cpp:1219: warning: ‘moab::ErrorCode moab::Interface::tag_create_variable_length(const char*, moab::TagType, moab::DataType, moab::TagInfo*&, const void*, int)’ is deprecated (declared at ../../src/moab/Interface.hpp:1252)
> ReadNC.cpp:1262: warning: ‘moab::ErrorCode moab::Interface::tag_create_variable_
> Iulian
> ----- Forwarded Message -----
>> Author: tautges
>> Date: 2011-06-03 15:08:04 -0500 (Fri, 03 Jun 2011)
>> New Revision: 4943
>> Added:
>> MOAB/trunk/MeshFiles/unittest/io/cam18x40x48.t2.nc
>> MOAB/trunk/test/io/read_nc.cpp
>> Modified:
>> MOAB/trunk/MeshFiles/unittest/io/Makefile.am
>> MOAB/trunk/src/io/ReadNC.cpp
>> MOAB/trunk/test/io/Makefile.am
>> Log:
>> Fixing a few bugs in the NC reader that were exposed by the new unit
>> test added here too.
>> mb_facet test still fails for me, but that was failing before.
>> Modified: MOAB/trunk/MeshFiles/unittest/io/Makefile.am
>> --- MOAB/trunk/MeshFiles/unittest/io/Makefile.am 2011-06-03 18:32:18
>> UTC (rev 4942)
>> +++ MOAB/trunk/MeshFiles/unittest/io/Makefile.am 2011-06-03 20:08:04
>> UTC (rev 4943)
>> @@ -1,6 +1,7 @@
>> EXTRA_DIST = brick_cubit10.1.cub \
>> brick_cubit10.2.cub \
>> brick_cubit10.cub \
>> + cam18x40x48.t2.nc \
>> cubtest12.cub \
>> cubtest.jou \
>> dum.sat \
>> Added: MOAB/trunk/MeshFiles/unittest/io/cam18x40x48.t2.nc
>> (Binary files differ)
>> Property changes on:
>> ___________________________________________________________________
>> Added: svn:mime-type
>> + application/octet-stream
>> Modified: MOAB/trunk/src/io/ReadNC.cpp
>> --- MOAB/trunk/src/io/ReadNC.cpp 2011-06-03 18:32:18 UTC (rev 4942)
>> +++ MOAB/trunk/src/io/ReadNC.cpp 2011-06-03 20:08:04 UTC (rev 4943)
>> @@ -375,6 +375,8 @@
>> if (tstep_nums.empty()&&  -1 != tMin) {
>> // no timesteps input, get them all
>> for (int i = tMin; i<= tMax; i++) tstep_nums.push_back(i);
>> + if (!tstep_nums.empty()) {
>> for (unsigned int i = 0; i<  vdatas.size(); i++) {
>> vdatas[i].varTags.resize(tstep_nums.size(), 0);
>> vdatas[i].varDatas.resize(tstep_nums.size());
>> @@ -398,7 +400,7 @@
>> // get the tag to read into
>> if (!vdatas[i].varTags[t]) {
>> - rval = get_tag(vdatas[i], t, vdatas[i].varTags[t]);
>> + rval = get_tag(vdatas[i], tstep_nums[t], vdatas[i].varTags[t]);
>> ERRORR(rval, "Trouble getting tag.");
>> @@ -523,7 +525,7 @@
>> for (unsigned int t = 0; t<  tstep_nums.size(); t++) {
>> dbgOut.tprintf(2, "Converting variable %s, time step %d\n",
>> vdatas[i].varName.c_str(), tstep_nums[t]);
>> - ErrorCode tmp_rval = convert_variable(file_set, vdatas[i],
>> tstep_nums[t]);
>> + ErrorCode tmp_rval = convert_variable(file_set, vdatas[i], t);
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
