[MOAB-dev] r4940 - in MOAB/trunk: src src/moab test
Tim Tautges tautges at mcs.anl.gov
Fri Jun 3 10:46:56 CDT 2011
Sometimes the geom topo sets will be created before the mesh is actually generated, is this still possible?  Maybe it
just fails the test, but that's ok?
- tim
On 06/03/2011 10:40 AM, iulian at mcs.anl.gov wrote:
> Author: iulian
> Date: 2011-06-03 10:40:53 -0500 (Fri, 03 Jun 2011)
> New Revision: 4940
> Modified:
>     MOAB/trunk/src/GeomTopoTool.cpp
>     MOAB/trunk/src/moab/GeomTopoTool.hpp
>     MOAB/trunk/test/gttool_test.cpp
> Log:
> add a method on GeomTopoTool for checking the model consistency
> for example:
>    vertex sets need to have one node inside
>    edge sets need to be ordered with mesh edges chained
>    edge ends need to be in children vertex sets
>    face/edge senses need to be consistent with the embedded mesh entities
>    face skins are indeed forming the boundary edges
> more checks might need to be added:
>    can we build edge loops?
>    face/region checks are not done yet
> Modified: MOAB/trunk/src/GeomTopoTool.cpp
> --- MOAB/trunk/src/GeomTopoTool.cpp	2011-06-03 03:30:59 UTC (rev 4939)
> +++ MOAB/trunk/src/GeomTopoTool.cpp	2011-06-03 15:40:53 UTC (rev 4940)
> @@ -1059,6 +1059,8 @@
>   // this would be a deep copy, into a new geom topo tool
>     // sets will be duplicated, but entities not
>     // modelSet will be a new one
> +  // if the original set was null (root), a new model set will be created for
> +  // original model, and its entities will be the original g sets
>   GeomTopoTool * GeomTopoTool::duplicate_model()
>     // will
> @@ -1181,10 +1183,202 @@
>           return NULL;
> +  // if the original root model set for this model is 0 (root set), then create
> +  // a new set and put all the old sets in the new model set
> +  // in this way, the existing gtt remains valid (otherwise, the modelSet would contain all the
> +  // gsets, the old ones and the new ones; the root set contains everything)
> +  if (modelSet==0)
> +    rval = mdbImpl->create_meshset(MESHSET_SET, modelSet);
> +    if (MB_SUCCESS != rval)
> +      return NULL;
> +    // add to this new set all previous sets (which are still in ranges)
> +    for (int dim=0; dim<4; dim++)
> +      rval = mdbImpl->add_entities(modelSet, geomRanges[dim]);
> +        return NULL;
>     return newgtt;
> +#define  RETFALSE(a) { std::cout<<a<<"\n"; return false; }
> +bool GeomTopoTool::check_model()
> +  // vertex sets should have one node
> +  Range::iterator rit;
> +  ErrorCode rval;
> +  for (rit = geomRanges[0].begin(); rit!=geomRanges[0].end(); rit++)
> +    EntityHandle vSet = *rit;
> +    Range nodes;
> +    rval = mdbImpl->get_entities_by_handle(vSet, nodes);
> +    if (MB_SUCCESS!=rval)
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
