[MOAB-dev] r4935 - MOAB/trunk/src/io
kraftche at cae.wisc.edu
Thu Jun 2 17:34:11 CDT 2011
Author: kraftche
Date: 2011-06-02 17:34:11 -0500 (Thu, 02 Jun 2011)
New Revision: 4935
Modified:
MOAB/trunk/src/io/ReadHDF5.cpp
Log:
minor change to ReadHDF5 debug output
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2011-06-02 21:45:47 UTC (rev 4934)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2011-06-02 22:34:11 UTC (rev 4935)
@@ -359,7 +359,6 @@
#endif
if (bglockless) {
pfilename = std::string("bglockless:") + pfilename;
- dbgOut.printf( 1, "Enabling lockless IO for BlueGene (filename: \"%s\")\n", pfilename.c_str() );
#ifndef HDF5_PARALLEL
@@ -382,6 +381,9 @@
dbgOut.set_rank(rank);
dbgOut.limit_output_to_first_N_procs( 32 );
mpiComm = new MPI_Comm(myPcomm->proc_config().proc_comm());
+ if (bglockless) {
+ dbgOut.printf( 1, "Enabling lockless IO for BlueGene (filename: \"%s\")\n", pfilename.c_str() );
#ifndef H5_MPI_COMPLEX_DERIVED_DATATYPE_WORKS
dbgOut.print(1,"H5_MPI_COMPLEX_DERIVED_DATATYPE_WORKS is not defined\n");
