[MOAB-dev] r4933 - MOAB/trunk/src/parallel
kraftche at cae.wisc.edu
Thu Jun 2 16:45:27 CDT 2011
Author: kraftche
Date: 2011-06-02 16:45:26 -0500 (Thu, 02 Jun 2011)
New Revision: 4933
Modified:
MOAB/trunk/src/parallel/ParallelComm.cpp
Log:
Fix accidental change to global/mesh value for tag when entity handle vector is empty
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp 2011-06-02 21:45:00 UTC (rev 4932)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp 2011-06-02 21:45:26 UTC (rev 4933)
@@ -3090,33 +3090,35 @@
RRA("Failed to get local handles for tag vals.");
- if (tag_size == MB_VARIABLE_LENGTH) {
- // Be careful of alignment here. If the integers are aligned
- // in the buffer, we can use them directly. Otherwise we must
- // copy them.
- std::vector<int> var_lengths(num_ents);
- UNPACK_INTS(buff_ptr, &var_lengths[0], num_ents);
- UPC(sizeof(int) * num_ents, " void");
- // get pointers into buffer for each tag value
- var_len_vals.resize(num_ents);
- for (std::vector<EntityHandle>::size_type j = 0;
- j < (std::vector<EntityHandle>::size_type) num_ents; ++j) {
- var_len_vals[j] = buff_ptr;
- buff_ptr += var_lengths[j];
- UPC(var_lengths[j], " void");
+ if (!dum_ents.empty()) {
+ if (tag_size == MB_VARIABLE_LENGTH) {
+ // Be careful of alignment here. If the integers are aligned
+ // in the buffer, we can use them directly. Otherwise we must
+ // copy them.
+ std::vector<int> var_lengths(num_ents);
+ UNPACK_INTS(buff_ptr, &var_lengths[0], num_ents);
+ UPC(sizeof(int) * num_ents, " void");
+ // get pointers into buffer for each tag value
+ var_len_vals.resize(num_ents);
+ for (std::vector<EntityHandle>::size_type j = 0;
+ j < (std::vector<EntityHandle>::size_type) num_ents; ++j) {
+ var_len_vals[j] = buff_ptr;
+ buff_ptr += var_lengths[j];
+ UPC(var_lengths[j], " void");
+ result = mbImpl->tag_set_data( tag_handle, &dum_ents[0], num_ents,
+ &var_len_vals[0], &var_lengths[0]);
+ RRA("Trouble setting tag data when unpacking variable-length tag.");
- result = mbImpl->tag_set_data( tag_handle, &dum_ents[0], num_ents,
- &var_len_vals[0], &var_lengths[0]);
- RRA("Trouble setting tag data when unpacking variable-length tag.");
+ else {
+ result = mbImpl->tag_set_data(tag_handle, &dum_ents[0],
+ num_ents, buff_ptr);
+ RRA("Trouble setting range-based tag data when unpacking tag.");
