[MOAB-dev] r4925 - in MOAB/trunk: src src/io src/parallel tools
kraftche at cae.wisc.edu
Thu Jun 2 10:50:06 CDT 2011
Author: kraftche
Date: 2011-06-02 10:50:06 -0500 (Thu, 02 Jun 2011)
New Revision: 4925
Modified:
MOAB/trunk/src/DebugOutput.hpp
MOAB/trunk/src/io/ReadHDF5.cpp
MOAB/trunk/src/io/WriteHDF5.cpp
MOAB/trunk/src/io/WriteHDF5.hpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.hpp
MOAB/trunk/tools/convert.cpp
Log:
o Add option to disable hyperslab append for HDF5 writer
o Limit debug output to first 32 procs for HDF5 read/write
o Limit non-error output of mbconvert to root process only
Modified: MOAB/trunk/src/DebugOutput.hpp
--- MOAB/trunk/src/DebugOutput.hpp 2011-06-02 15:45:42 UTC (rev 4924)
+++ MOAB/trunk/src/DebugOutput.hpp 2011-06-02 15:50:06 UTC (rev 4925)
@@ -135,6 +135,10 @@
//! or zero if MOAB is build w/out MPI.
void use_world_rank();
+ //!\brief Only print debug output from N processes
+ void limit_output_to_first_N_procs( int N )
+ { if (mpiRank >= N) verbosityLimit = 0; }
//!\brief Get verbosity limit
unsigned get_verbosity() const { return verbosityLimit; }
//!\brief Set verbosity limit
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2011-06-02 15:45:42 UTC (rev 4924)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2011-06-02 15:50:06 UTC (rev 4925)
@@ -304,6 +304,7 @@
dbgOut.set_verbosity(tmpval);
dbgOut.set_prefix("H5M ");
+ dbgOut.limit_output_to_first_N_procs( 32 );
// Enable some extra checks for reads. Note: amongst other things this
// will print errors if the entire file is not read, so if doing a
Modified: MOAB/trunk/src/io/WriteHDF5.cpp
--- MOAB/trunk/src/io/WriteHDF5.cpp 2011-06-02 15:45:42 UTC (rev 4924)
+++ MOAB/trunk/src/io/WriteHDF5.cpp 2011-06-02 15:50:06 UTC (rev 4925)
@@ -636,15 +636,13 @@
int junk;
parallelWrite = (MB_SUCCESS == opts.match_option( "PARALLEL", optnames, junk ));
if (parallelWrite) {
- int pcomm_no = 0;
- opts.get_int_option("PARALLEL_COMM", pcomm_no);
// Just store Boolean value based on string option here.
// parallel_create_file will set writeProp accordingly.
//collectiveIO = (MB_SUCCESS == opts.get_null_option("COLLECTIVE"));
//dbgOut.printf(2,"'COLLECTIVE' option = %s\n", collectiveIO ? "YES" : "NO" );
// Do this all the time, as it appears to be much faster than indep in some cases
collectiveIO = true;
- result = parallel_create_file( filename, overwrite, qa_records, tag_list, num_tags, user_dimension, pcomm_no, times );
+ result = parallel_create_file( filename, overwrite, qa_records, opts, tag_list, num_tags, user_dimension, times );
else {
result = serial_create_file( filename, overwrite, qa_records, tag_list, num_tags, user_dimension );
@@ -2491,10 +2489,10 @@
