[MOAB-dev] r4911 - MOAB/trunk/src/io
xbxu at mcs.anl.gov xbxu at mcs.anl.gov
Wed Jun 1 16:35:57 CDT 2011
Author: xbxu
Date: 2011-06-01 16:35:55 -0500 (Wed, 01 Jun 2011)
New Revision: 4911
Modified:
   MOAB/trunk/src/io/ReadNC.cpp
   MOAB/trunk/src/io/ReadNC.hpp
Log:
Addd function to create NC Climate Data conventional tags
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp	2011-06-01 20:34:51 UTC (rev 4910)
+++ MOAB/trunk/src/io/ReadNC.cpp	2011-06-01 21:35:55 UTC (rev 4911)
@@ -170,6 +170,10 @@
 #endif
+    // create nc conventional tags
+  rval = create_tags(tstep_nums);
+  ERRORR(rval, "Trouble creating nc conventional tags.");
   return MB_SUCCESS;
@@ -617,7 +621,7 @@
   std::ostringstream tag_name;
   tag_name << var_data.varName;
-  if (0 != tstep_num) tag_name << tstep_num;
+  tag_name << tstep_num;
   ErrorCode rval = MB_SUCCESS;
   tagh = 0;
   switch (var_data.varDataType) {
@@ -1077,4 +1081,174 @@
   return MB_FAILURE;
+ErrorCode ReadNC::create_tags(const std::vector<int>& tstep_nums)
+  ErrorCode rval;
+  std::string tag_name;
+  // <__NUM_DIMS>
+  Tag numDimsTag = 0;
+  tag_name = "__NUM_DIMS";
+  int numDims = dimNames.size();
+  rval = mbImpl->tag_create(tag_name.c_str(), sizeof(int), MB_TAG_SPARSE, MB_TYPE_INTEGER, numDimsTag, &numDims);
+  ERRORR(rval, "Trouble creating __NUM_DIMS tag.");
+  if (MB_SUCCESS == rval) dbgOut.tprintf(2, "Tag created for variable %s\n", tag_name.c_str());
+  // <__NUM_VARS>
+  Tag numVarsTag = 0;
+  tag_name = "__NUM_VARS";
+  int numVars = varInfo.size();
+  rval = mbImpl->tag_create(tag_name.c_str(), sizeof(int), MB_TAG_SPARSE, MB_TYPE_INTEGER, numVarsTag, &numVars);
+  ERRORR(rval, "Trouble creating __NUM_VARS tag.");
+  // <__DIM_NAMES>
+  Tag dimNamesTag = 0;
