[MOAB-dev] r4891 - MOAB/trunk/src/parallel
hongjun at mcs.anl.gov
Fri May 27 13:00:19 CDT 2011
Author: hongjun
Date: 2011-05-27 13:00:18 -0500 (Fri, 27 May 2011)
New Revision: 4891
Modified:
MOAB/trunk/src/parallel/ParallelComm.cpp
Log:
o Communication buffers are newly created in "exchange_owned_mesh"
o Passes make check
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp 2011-05-27 13:02:12 UTC (rev 4890)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp 2011-05-27 18:00:18 UTC (rev 4891)
@@ -1719,7 +1719,7 @@
bool created_here = false;
if (!new_h && !is_iface) {
if (MBVERTEX == this_type) {
// create a vertex
result = mbImpl->create_vertex(coords, new_h);
@@ -4779,7 +4779,7 @@
// send 2nd message
PRINT_DEBUG_ISEND(procConfig.proc_rank(), from_proc,
send_buff->mem_ptr+INITIAL_BUFF_SIZE,
@@ -4803,7 +4803,7 @@
// message completely received - signal that we're done
done = true;
return MB_SUCCESS;
@@ -5334,6 +5334,10 @@
ErrorCode result = MB_SUCCESS;
int incoming1 = 0, incoming2 = 0;
+ // clear all buffers
+ delete_all_buffers();
+ buffProcs.clear();
// set buffProcs with communicating procs
int n_proc = exchange_procs.size();
for (i = 0; i < n_proc; i++) {
@@ -5363,10 +5367,8 @@
// index reqs the same as buffer/sharing procs indices
std::vector<MPI_Request> recv_ent_reqs(2*buffProcs.size(), MPI_REQUEST_NULL),
recv_remoteh_reqs(2*buffProcs.size(), MPI_REQUEST_NULL);
- std::vector<unsigned int>::iterator proc_it;
sendReqs.resize(2*buffProcs.size(), MPI_REQUEST_NULL);
- for (i = 0; i < n_proc; i++) {
- ind = get_buffers(exchange_procs[i]);
+ for (ind = 0; ind < buffProcs.size(); ind++) {
