[MOAB-dev] r4880 - MOAB/trunk/src
kraftche at cae.wisc.edu
Wed May 25 18:07:37 CDT 2011
Author: kraftche
Date: 2011-05-25 18:07:35 -0500 (Wed, 25 May 2011)
New Revision: 4880
Modified:
MOAB/trunk/src/Core.cpp
Log:
when using new tag_get_handle function to get a handle for a variable length tag, don't require the caller to specify MB_TAG_VARLEN. specifying a zero length is sufficient to indicate that the caller knows it is asking for a variable-length tag
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp 2011-05-25 18:33:20 UTC (rev 4879)
+++ MOAB/trunk/src/Core.cpp 2011-05-25 23:07:35 UTC (rev 4880)
@@ -2057,11 +2057,22 @@
else if (extype != MB_TYPE_OPAQUE && type != MB_TYPE_OPAQUE)
return MB_TYPE_OUT_OF_RANGE;
- // check if varlen matches
- if (!(flags & MB_TAG_VARLEN) == tag_handle->variable_length())
+ // Require that the size value be zero or MB_VARIABLE_LENGTH
+ // for variable length tags. The caller passing such a size
+ // value is sufficient to indicate that the caller is aware
+ // that it is requesting a variable-length tag, so no need
+ // to also require/check the MB_TAG_VARLEN bit in the flags.
+ if (tag_handle->variable_length()) {
+ if (size != 0 && size != MB_VARIABLE_LENGTH)
+ return MB_INVALID_SIZE;
+ // But /do/ fail if MB_TAG_VARLEN flag is set and tag is
+ // not variable length.
+ else if (flags & MB_TAG_VARLEN)
- // check sizes
- if (!(flags & MB_TAG_VARLEN) && tag_handle->get_size() != size)
+ // check size for fixed-length tag
+ else if (tag_handle->get_size() != size)
// If user passed a default value, check that it matches.
