[MOAB-dev] build question
Tim Tautges
tautges at mcs.anl.gov
Tue May 24 10:51:53 CDT 2011
I tried on my laptop, which is a fairly standard Ubuntu, and it worked fine.
One thing I note about your configuration is that you're using a /home/fathom/... mpi, while that directory isn't in
your LD_LIBRARY_PATH. Might be you're finding a different mpirun or mpi libs (not sure if they're typically .so's?)
- tim
On 05/24/2011 10:44 AM, Iulian Grindeanu wrote:
>> What is the error message?
> make check
> make[4]: Entering directory `/sandbox/src/MOAB/itaps/imesh'
> make[5]: Entering directory `/sandbox/src/MOAB/itaps/imesh'
> FAIL: testc_cbind
> FAIL: MOAB_iMesh_unit_tests
> FAIL: partest
> FAIL: MOAB_iMeshP_unit_tests
> 4 of 4 tests failed
> See itaps/imesh/test-suite.log
> src/MOAB> more itaps/imesh/test-suite.log
> MOAB 4.1.0pre: itaps/imesh/test-suite.log
> 4 of 4 tests failed.
> .. contents:: :depth: 2
> FAIL: testc_cbind (exit: 1)
> Attempting to use an MPI routine before initializing MPICH
> FAIL: MOAB_iMesh_unit_tests (exit: 1)
> FAIL: partest (exit: 1)
> The debugger will not start, and I don't know which one is called before MPI_Init
>> Is CGM built as a static library? Other required libraries?
> I do not specify static or shared, so it is static, default.
> The same with MOAB;
> Other required libraries are build shared, mostly, and I do have LD_LIBRARY_PATH specified
> echo $LD_LIBRARY_PATH
> /homes/hongjun/lib/camal.5.1.0-Linux64/lib/Linux64:/home/fathom/3rdparty/cubit/Cubit64/Cubit-12.2/bin:/homes/fathom/3rdparty/szip/szip-2.1/gcc/lib:/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib:/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib:/homes/fathom/3rdparty/occ/OpenCASCADE6.3.0/gcc/lib:/homes/iulian/python_libs/lib:/homes/jain/libccmio-2.06.020/linux/64/lib:/soft/apps/packages/libgfortran
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
