[MOAB-dev] build question
Iulian Grindeanu iulian at mcs.anl.gov
Tue May 24 10:44:55 CDT 2011
> What is the error message?
  make check
make[4]: Entering directory `/sandbox/src/MOAB/itaps/imesh'
make[5]: Entering directory `/sandbox/src/MOAB/itaps/imesh'
FAIL: testc_cbind
FAIL: MOAB_iMesh_unit_tests
FAIL: partest
FAIL: MOAB_iMeshP_unit_tests
4 of 4 tests failed
See itaps/imesh/test-suite.log
src/MOAB> more itaps/imesh/test-suite.log
   MOAB 4.1.0pre: itaps/imesh/test-suite.log
4 of 4 tests failed.
.. contents:: :depth: 2
FAIL: testc_cbind (exit: 1)
Attempting to use an MPI routine before initializing MPICH
FAIL: MOAB_iMesh_unit_tests (exit: 1)
FAIL: partest (exit: 1)
The debugger will not start, and I don't know which one is called before MPI_Init
> Is CGM built as a static library? Other required libraries?
I do not specify static or shared, so it is static, default.
The same with MOAB;
Other required libraries are build shared, mostly, and I do have LD_LIBRARY_PATH specified
echo $LD_LIBRARY_PATH
/homes/hongjun/lib/camal.5.1.0-Linux64/lib/Linux64:/home/fathom/3rdparty/cubit/Cubit64/Cubit-12.2/bin:/homes/fathom/3rdparty/szip/szip-2.1/gcc/lib:/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib:/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib:/homes/fathom/3rdparty/occ/OpenCASCADE6.3.0/gcc/lib:/homes/iulian/python_libs/lib:/homes/jain/libccmio-2.06.020/linux/64/lib:/soft/apps/packages/libgfortran
