[MOAB-dev] buildbot failure in moab-distcheck: failed compile
    Tim Tautges
    tautges at mcs.anl.gov
    Fri May 20 09:10:35 CDT 2011
Hi all,
   This is a good reminder of two things:
1. Sometimes it's advisable to run not make check, but make distcheck, to check big changes to MOAB code
2. It's useful to have a nightly buildbot running multiple jobs, to catch things like this, since even the most
experienced get caught by this once in awhile.
- tim
On 05/20/2011 12:25 AM, moab-dev at mcs.anl.gov wrote:
>   Fathom <http://gnep.mcs.anl.gov:8010/>: moab-distcheck
>   <http://gnep.mcs.anl.gov:8010/builders/moab-distcheck> build #506
>   <http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/506>
> *Results:*	failed compile
> *Buildslave:*	gnep
> *Revision:*	None
> *Reason:*	The Nightly scheduler named 'nightly' triggered this build
>     Log Excerpt
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT MeshSetSequence.lo -MD -MP -MF .deps/MeshSetSequence.Tpo -c -o MeshSetSequence.lo ../../src/MeshSetSequence.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT MeshSetSequence.lo -MD -MP -MF .deps/MeshSetSequence.Tpo -c ../../src/MeshSetSequence.cpp -o MeshSetSequence.o
> mv -f .deps/MeshSetSequence.Tpo .deps/MeshSetSequence.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT MeshTag.lo -MD -MP -MF .deps/MeshTag.Tpo -c -o MeshTag.lo ../../src/MeshTag.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT MeshTag.lo -MD -MP -MF .deps/MeshTag.Tpo -c ../../src/MeshTag.cpp -o MeshTag.o
> mv -f .deps/MeshTag.Tpo .deps/MeshTag.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT MeshTopoUtil.lo -MD -MP -MF .deps/MeshTopoUtil.Tpo -c -o MeshTopoUtil.lo ../../src/MeshTopoUtil.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT MeshTopoUtil.lo -MD -MP -MF .deps/MeshTopoUtil.Tpo -c ../../src/MeshTopoUtil.cpp -o MeshTopoUtil.o
> mv -f .deps/MeshTopoUtil.Tpo .deps/MeshTopoUtil.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT OrientedBox.lo -MD -MP -MF .deps/OrientedBox.Tpo -c -o OrientedBox.lo ../../src/OrientedBox.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT OrientedBox.lo -MD -MP -MF .deps/OrientedBox.Tpo -c ../../src/OrientedBox.cpp -o OrientedBox.o
> mv -f .deps/OrientedBox.Tpo .deps/OrientedBox.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT OrientedBoxTreeTool.lo -MD -MP -MF .deps/OrientedBoxTreeTool.Tpo -c -o OrientedBoxTreeTool.lo ../../src/OrientedBoxTreeTool.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT OrientedBoxTreeTool.lo -MD -MP -MF .deps/OrientedBoxTreeTool.Tpo -c ../../src/OrientedBoxTreeTool.cpp -o OrientedBoxTreeTool.o
> mv -f .deps/OrientedBoxTreeTool.Tpo .deps/OrientedBoxTreeTool.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT PolyElementSeq.lo -MD -MP -MF .deps/PolyElementSeq.Tpo -c -o PolyElementSeq.lo ../../src/PolyElementSeq.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT PolyElementSeq.lo -MD -MP -MF .deps/PolyElementSeq.Tpo -c ../../src/PolyElementSeq.cpp -o PolyElementSeq.o
> mv -f .deps/PolyElementSeq.Tpo .deps/PolyElementSeq.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT Range.lo -MD -MP -MF .deps/Range.Tpo -c -o Range.lo ../../src/Range.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT Range.lo -MD -MP -MF .deps/Range.Tpo -c ../../src/Range.cpp -o Range.o
> mv -f .deps/Range.Tpo .deps/Range.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT RangeSeqIntersectIter.lo -MD -MP -MF .deps/RangeSeqIntersectIter.Tpo -c -o RangeSeqIntersectIter.lo ../../src/RangeSeqIntersectIter.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT RangeSeqIntersectIter.lo -MD -MP -MF .deps/RangeSeqIntersectIter.Tpo -c ../../src/RangeSeqIntersectIter.cpp -o RangeSeqIntersectIter.o
> mv -f .deps/RangeSeqIntersectIter.Tpo .deps/RangeSeqIntersectIter.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT ReadUtil.lo -MD -MP -MF .deps/ReadUtil.Tpo -c -o ReadUtil.lo ../../src/ReadUtil.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT ReadUtil.lo -MD -MP -MF .deps/ReadUtil.Tpo -c ../../src/ReadUtil.cpp -o ReadUtil.o
> mv -f .deps/ReadUtil.Tpo .deps/ReadUtil.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT ReaderWriterSet.lo -MD -MP -MF .deps/ReaderWriterSet.Tpo -c -o ReaderWriterSet.lo ../../src/ReaderWriterSet.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT ReaderWriterSet.lo -MD -MP -MF .deps/ReaderWriterSet.Tpo -c ../../src/ReaderWriterSet.cpp -o ReaderWriterSet.o
> mv -f .deps/ReaderWriterSet.Tpo .deps/ReaderWriterSet.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT ScdElementData.lo -MD -MP -MF .deps/ScdElementData.Tpo -c -o ScdElementData.lo ../../src/ScdElementData.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT ScdElementData.lo -MD -MP -MF .deps/ScdElementData.Tpo -c ../../src/ScdElementData.cpp -o ScdElementData.o
> mv -f .deps/ScdElementData.Tpo .deps/ScdElementData.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT ScdInterface.lo -MD -MP -MF .deps/ScdInterface.Tpo -c -o ScdInterface.lo ../../src/ScdInterface.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT ScdInterface.lo -MD -MP -MF .deps/ScdInterface.Tpo -c ../../src/ScdInterface.cpp -o ScdInterface.o
> mv -f .deps/ScdInterface.Tpo .deps/ScdInterface.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT ScdVertexData.lo -MD -MP -MF .deps/ScdVertexData.Tpo -c -o ScdVertexData.lo ../../src/ScdVertexData.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT ScdVertexData.lo -MD -MP -MF .deps/ScdVertexData.Tpo -c ../../src/ScdVertexData.cpp -o ScdVertexData.o
> mv -f .deps/ScdVertexData.Tpo .deps/ScdVertexData.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT SequenceData.lo -MD -MP -MF .deps/SequenceData.Tpo -c -o SequenceData.lo ../../src/SequenceData.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT SequenceData.lo -MD -MP -MF .deps/SequenceData.Tpo -c ../../src/SequenceData.cpp -o SequenceData.o
> mv -f .deps/SequenceData.Tpo .deps/SequenceData.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT SequenceManager.lo -MD -MP -MF .deps/SequenceManager.Tpo -c -o SequenceManager.lo ../../src/SequenceManager.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT SequenceManager.lo -MD -MP -MF .deps/SequenceManager.Tpo -c ../../src/SequenceManager.cpp -o SequenceManager.o
> mv -f .deps/SequenceManager.Tpo .deps/SequenceManager.Plo
> /bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel  -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE  -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT SetIterator.lo -MD -MP -MF .deps/SetIterator.Tpo -c -o SetIterator.lo ../../src/SetIterator.cpp
> libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../src -I.. -I../src/moab -I../src/parallel -I/home/jvporter/packages/hdf5-x64-serial/include -isystem /home/jvporter/packages/hdf5-x64-serial/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../src/io -I../../src/io/mhdf/include -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT SetIterator.lo -MD -MP -MF .deps/SetIterator.Tpo -c ../../src/SetIterator.cpp -o SetIterator.o
> ../../src/SetIterator.cpp:10:18: error: CN.hpp: No such file or directory
> ../../src/SetIterator.cpp: In constructor ‘moab::RangeSetIterator::RangeSetIterator(moab::Core*, moab::EntityHandle, int, moab::EntityType, int, bool)’:
> ../../src/SetIterator.cpp:28: warning: unused variable ‘rval’
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
