[MOAB-dev] make check errors
Iulian Grindeanu
iulian at mcs.anl.gov
Fri May 20 09:09:35 CDT 2011
Hello,
I have an error I do not understand.
The static parallel MOAB build, based on cgm-occ works fine, make check passes
The shared parallel MOAB build, based on cubit 12.2 builds fine, but most of the checks fail, with the message like this
FAIL: testc_cbind (exit: 1)
Attempting to use an MPI routine before initializing MPICH
I did a 'make distclean' and rebuilt everything, but the same error, on the shared build.
My config.log is attached, just in case.
Any suggestions?
Iulian
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110520/2440f929/attachment-0001.bin>
