[MOAB-dev] r4852 - in MOAB/trunk/src: io parallel
iulian at mcs.anl.gov iulian at mcs.anl.gov
Thu May 19 23:59:25 CDT 2011
Author: iulian
Date: 2011-05-19 23:59:25 -0500 (Thu, 19 May 2011)
New Revision: 4852
Modified:
   MOAB/trunk/src/io/HDF5Common.hpp
   MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
Log:
compile errors on mpi build
Modified: MOAB/trunk/src/io/HDF5Common.hpp
--- MOAB/trunk/src/io/HDF5Common.hpp	2011-05-19 21:50:23 UTC (rev 4851)
+++ MOAB/trunk/src/io/HDF5Common.hpp	2011-05-20 04:59:25 UTC (rev 4852)
@@ -1,6 +1,6 @@
 #include <H5Epublic.h>
+#include <H5Spublic.h>
 namespace moab {
 extern "C" {
Modified: MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp	2011-05-19 21:50:23 UTC (rev 4851)
+++ MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp	2011-05-20 04:59:25 UTC (rev 4852)
@@ -566,7 +566,7 @@
     /* Test if we can use H5S_APPEND when selecting hyperslabs */
   if (HDF5_can_append_hyperslabs()) {
-    dbgOut.print(1,"HDF5 library supports H5Sselect_hyperlsab with H5S_SELECT_APPEND"\n);
+    dbgOut.print(1,"HDF5 library supports H5Sselect_hyperlsab with H5S_SELECT_APPEND\n");
     hslabOp = H5S_SELECT_APPEND;
