[MOAB-dev] r4850 - in MOAB/trunk/src: io parallel
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu May 19 15:15:31 CDT 2011
Author: kraftche
Date: 2011-05-19 15:15:31 -0500 (Thu, 19 May 2011)
New Revision: 4850
Added:
   MOAB/trunk/src/io/HDF5Common.cpp
   MOAB/trunk/src/io/HDF5Common.hpp
Modified:
   MOAB/trunk/src/io/Makefile.am
   MOAB/trunk/src/io/ReadHDF5.cpp
   MOAB/trunk/src/io/ReadHDF5.hpp
   MOAB/trunk/src/io/WriteHDF5.hpp
   MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
   MOAB/trunk/src/parallel/WriteHDF5Parallel.hpp
Log:
auto-detect application of HDF5 hyperslab append hack
Added: MOAB/trunk/src/io/HDF5Common.cpp
--- MOAB/trunk/src/io/HDF5Common.cpp	                        (rev 0)
+++ MOAB/trunk/src/io/HDF5Common.cpp	2011-05-19 20:15:31 UTC (rev 4850)
@@ -0,0 +1,42 @@
+#include <HDF5Common.hpp>
+#include <H5Spublic.h>
+#include <assert.h>
+namespace moab {
+bool HDF5_can_append_hyperslabs()
+  hsize_t dim = 100;
+  hid_t space = H5Screate_simple( 1, &dim, NULL );
+  bool result = false;
+  HDF5_Error_Func_Type fptr = 0;
+  void* fdata = 0;
+#if defined(H5Eget_auto_vers) && H5Eget_auto_vers > 1
+  if (0 <= H5Eget_auto( H5E_DEFAULT, &fptr, &fdata ))
+    H5Eset_auto( H5E_DEFAULT, 0, 0 );
+#else
+  if (0 <= H5Eget_auto( &fptr, &fdata ))
+    H5Eset_auto( 0, 0 );
+#endif
+  hsize_t start = 1, count = 5;
+  H5Sselect_hyperslab( space, H5S_SELECT_SET, &start, 0, &count, 0 );
+  start = 20;
+  if (0 <= H5Sselect_hyperslab( space, H5S_SELECT_APPEND, &start, 0, &count, 0 ))
+    result = true;
+  if (fptr) {
+#if defined(H5Eset_auto_vers) && H5Eset_auto_vers > 1
+    H5Eset_auto( H5E_DEFAULT, fptr, fdata );
+#else
+    H5Eset_auto( fptr, fdata );
+#endif
+  H5Sclose( space );
+  return result;
Added: MOAB/trunk/src/io/HDF5Common.hpp
--- MOAB/trunk/src/io/HDF5Common.hpp	                        (rev 0)
