[MOAB-dev] r4847 - in MOAB/trunk/src: io parallel
kraftche at cae.wisc.edu
Wed May 18 17:50:04 CDT 2011
Author: kraftche
Date: 2011-05-18 17:50:03 -0500 (Wed, 18 May 2011)
New Revision: 4847
Modified:
MOAB/trunk/src/io/WriteHDF5.cpp
MOAB/trunk/src/io/WriteHDF5.hpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.hpp
Log:
Improve "CPUTIME" writer option for WriteHDF5(Parallel):
o More fine-grained timing data
o Print max over all procs from root if parallel
Modified: MOAB/trunk/src/io/WriteHDF5.cpp
--- MOAB/trunk/src/io/WriteHDF5.cpp 2011-05-18 22:13:06 UTC (rev 4846)
+++ MOAB/trunk/src/io/WriteHDF5.cpp 2011-05-18 22:50:03 UTC (rev 4847)
@@ -59,6 +59,15 @@
#define RUNTIME (clock()/(double)CLOCKS_PER_SEC)
#endif
+class CpuTimer {
+private:
+ double atBirth, atLast;
+public:
+ CpuTimer() : atBirth(RUNTIME), atLast(atBirth) {}
+ double since_birth() { return (atLast = RUNTIME) - atBirth; };
+ double elapsed() { double tmp = atLast; return (atLast = RUNTIME) - tmp; }
/* Access HDF5 file handle for debugging
#include <H5Fpublic.h>
struct file { uint32_t magic; hid_t handle; };
@@ -135,7 +144,6 @@
static inline ErrorCode error( ErrorCode rval )
{ return rval; }
// Call \c error function during HDF5 library errors to make
// it easier to trap such errors in the debugger. This function
// gets registered with the HDF5 library as a callback. It
@@ -296,7 +304,6 @@
CheckOpenWriteHDF5Handles check_open_handles_(filePtr,__LINE__)
#endif
bool WriteHDF5::convert_handle_tag( const EntityHandle* source,
EntityHandle* dest, size_t count ) const
@@ -482,9 +489,8 @@
// Enable debug output
int tmpval = 0;
- if (MB_SUCCESS == opts.get_int_option("DEBUG_IO", 1, tmpval)) {
+ if (MB_SUCCESS == opts.get_int_option("DEBUG_IO", 1, tmpval))
dbgOut.set_verbosity(tmpval);
//writeTagDense = (MB_SUCCESS == opts.get_null_option("DENSE_TAGS"));
writeTagDense = true;
@@ -565,7 +571,7 @@
std::list<TagDesc>::const_iterator t_itor;
std::list<ExportSet>::iterator ex_itor;
EntityHandle elem_count, max_id;
