[MOAB-dev] r4843 - in MOAB/trunk: src src/moab test
iulian at mcs.anl.gov
Wed May 18 14:07:20 CDT 2011
Author: iulian
Date: 2011-05-18 14:07:20 -0500 (Wed, 18 May 2011)
New Revision: 4843
Modified:
MOAB/trunk/src/GeomTopoTool.cpp
MOAB/trunk/src/moab/GeomTopoTool.hpp
MOAB/trunk/test/gttool_test.cpp
Log:
use the senses of old model for duplicated model
correct edge sets
Modified: MOAB/trunk/src/GeomTopoTool.cpp
--- MOAB/trunk/src/GeomTopoTool.cpp 2011-05-18 18:19:49 UTC (rev 4842)
+++ MOAB/trunk/src/GeomTopoTool.cpp 2011-05-18 19:07:20 UTC (rev 4843)
@@ -763,8 +763,9 @@
ErrorCode rval;
if (!sense2Tag && create) {
+ EntityHandle def_val[2] = {0, 0};
rval = mdbImpl->tag_create(GEOM_SENSE_2_TAG_NAME, 2 * sizeof(EntityHandle),
- MB_TAG_SPARSE, MB_TYPE_HANDLE, sense2Tag, 0, true);
+ MB_TAG_SPARSE, MB_TYPE_HANDLE, sense2Tag, def_val, true);
if (MB_SUCCESS != rval && (MB_ALREADY_ALLOCATED != rval || !sense2Tag))
return MB_FAILURE;
@@ -1086,11 +1087,12 @@
for (int dim=0; dim<4; dim++)
int gid = 0;
+ unsigned int set_options = ( (1!=dim) ? MESHSET_SET : MESHSET_ORDERED );
for (Range::iterator it=geomRanges[dim].begin(); it!=geomRanges[dim].end(); it++)
EntityHandle set=*it;
EntityHandle newSet;
- rval = mdbImpl->create_meshset(MESHSET_SET, newSet);
+ rval = mdbImpl->create_meshset(set_options, newSet);
if (MB_SUCCESS!=rval)
return NULL;
relate[set] = newSet;
@@ -1105,13 +1107,27 @@
rval = mdbImpl->tag_set_data(gidTag, &newSet, 1, &gid);
return NULL;
- Range ents;
- rval = mdbImpl->get_entities_by_handle(set, ents);
- if (MB_SUCCESS!=rval)
- return NULL;
- rval = mdbImpl->add_entities(newSet, ents);
- return NULL;
+ if (dim==1)
+ // the entities are ordered, we need to retrieve them ordered, and set them ordered
+ std::vector<EntityHandle> mesh_edges;
+ rval = mdbImpl->get_entities_by_handle(set, mesh_edges);
+ if (MB_SUCCESS!=rval)
+ return NULL;
+ rval = mdbImpl->add_entities(newSet, &(mesh_edges[0]), (int)mesh_edges.size());
+ return NULL;
