[MOAB-dev] r4841 - in MOAB/trunk: src src/moab test
iulian at mcs.anl.gov
Wed May 18 01:20:37 CDT 2011
Author: iulian
Date: 2011-05-18 01:20:37 -0500 (Wed, 18 May 2011)
New Revision: 4841
Modified:
MOAB/trunk/src/GeomTopoTool.cpp
MOAB/trunk/src/moab/GeomTopoTool.hpp
MOAB/trunk/test/gttool_test.cpp
Log:
add a method to duplicate a model, by copying the geo sets
the entities are copied to the new sets, but they are not duplicated
the sense tags are set in the new model by using restore_topology method
Modified: MOAB/trunk/src/GeomTopoTool.cpp
--- MOAB/trunk/src/GeomTopoTool.cpp 2011-05-18 03:47:02 UTC (rev 4840)
+++ MOAB/trunk/src/GeomTopoTool.cpp 2011-05-18 06:20:37 UTC (rev 4841)
@@ -1059,6 +1059,86 @@
return MB_SUCCESS;
+// this would be a deep copy, into a new geom topo tool
+ // sets will be duplicated, but entities not
+ // modelSet will be a new one
+GeomTopoTool * GeomTopoTool::duplicate_model()
+ // will
+ EntityHandle rootModelSet;
+ ErrorCode rval = mdbImpl->create_meshset(MESHSET_SET, rootModelSet);
+ if (MB_SUCCESS!=rval)
+ return NULL;
+ if (0 == geomTag) {
+ rval = mdbImpl->tag_get_handle(GEOM_DIMENSION_TAG_NAME, geomTag);
+ if (MB_SUCCESS != rval)
+ return NULL;
+ if (0 == gidTag) {
+ rval = mdbImpl->tag_get_handle(GLOBAL_ID_TAG_NAME, gidTag);
+ return NULL;
+ // add to the root model set copies of the gsets, with correct sets
+ // keep a map between sets to help in copying parent/child relations
+ std::map <EntityHandle, EntityHandle> relate;
+ // each set will get the same entities as the original
+ for (int dim=0; dim<4; dim++)
+ int gid = 0;
+ for (Range::iterator it=geomRanges[dim].begin(); it!=geomRanges[dim].end(); it++)
+ EntityHandle set=*it;
+ EntityHandle newSet;
+ rval = mdbImpl->create_meshset(MESHSET_SET, newSet);
+ return NULL;
+ relate[set] = newSet;
+ rval = mdbImpl->add_entities(rootModelSet, &newSet, 1);
+ return NULL;
+ // make it a geo set, and give also global id in order
+ rval = mdbImpl->tag_set_data(geomTag, &newSet, 1, &dim);
+ return NULL;
+ gid++;// increment global id, everything starts with 1 in the new model!
