[MOAB-dev] r4836 - MOAB/trunk/src/io
Steve Jackson
sjackson at cae.wisc.edu
Tue May 17 16:05:10 CDT 2011
This revision seems to break non-MPI builds-- MPI_Abort and comm go undeclared.
~S
On May 17, 2011, at 11:26 , kraftche at cae.wisc.edu wrote:
> Author: kraftche
> Date: 2011-05-17 11:26:57 -0500 (Tue, 17 May 2011)
> New Revision: 4836
> Modified:
> MOAB/trunk/src/io/ReadHDF5.cpp
> Log:
> add some checks to HDF5 reader
> Modified: MOAB/trunk/src/io/ReadHDF5.cpp
> --- MOAB/trunk/src/io/ReadHDF5.cpp 2011-05-17 13:25:17 UTC (rev 4835)
> +++ MOAB/trunk/src/io/ReadHDF5.cpp 2011-05-17 16:26:57 UTC (rev 4836)
> @@ -2111,7 +2111,7 @@
> hid_t contents_handle,
> hid_t meta_type,
> hid_t content_type,
> - long /*contents_len*/,
> + long contents_len,
> Range& file_ids )
> @@ -2190,6 +2190,27 @@
> assert(rank == 0); // if not MPI, then only one proc
> #endif
> + // check offsets so that we don't read past end of table or
> + // walk off end of array.
> + long prev = -1;
> + for (long i = 0; i < num_sets; ++i) {
> + if (offset_buffer[i] < prev) {
> + std::cerr << "Invalid data in set contents offsets at position "
> + << i << ": index " << offset_buffer[i]
> + << " is less than previous index " << prev << std::endl;
> + std::cerr.flush();
> + MPI_Abort(comm,1);
> + prev = offset_buffer[i];
> + if (offset_buffer[num_sets-1] >= contents_len) {
> + std::cerr << "Maximum set content index " << offset_buffer[num_sets-1]
> + << " exceeds contents table length of " << contents_len
> + << std::endl;
> // set up buffer for reading set contents
> long* const content_buffer = (long*)dataBuffer;
