[MOAB-dev] New mailing lists for lasso
Tim Tautges tautges at mcs.anl.gov
Mon May 16 15:25:38 CDT 2011
Ugh, one of the things I'd meant to write, but forgot to, was what Lasso is... Lasso is a component for recovering and
querying relations between mesh and geometry (and other data, eventually).  Using lasso, you can load geometry/mesh into
CGM/MOAB, then recover the mesh to geometry associativity that existed when the mesh was generated.  If you're working
from CUBIT, this only works by saving the geometry and mesh in a .cub file, then reading that same file into CGM and
MOAB, then using Lasso to infer the relations.
For more information, see the Lasso wiki page at http://trac.mcs.anl.gov/projects/ITAPS/wiki/Lasso.
- tim
On 05/16/2011 03:21 PM, Tim Tautges wrote:
> Hi all,
> We've created new mailing lists for Lasso, lasso-dev and lasso-announce,
> both @mcs.anl.gov. -dev receives all commit messages, and discussion of
> Lasso/iRel design issues. -announce is relatively low-traffic, receiving
> messages about releases and other general information. You can request
> membership by going to the sites:
> https://lists.mcs.anl.gov/mailman/listinfo/lasso-dev
> https://lists.mcs.anl.gov/mailman/listinfo/lasso-announce
> - tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
