[MOAB-dev] r4818 - MOAB/trunk/tools
kraftche at cae.wisc.edu
Thu May 12 10:13:01 CDT 2011
Author: kraftche
Date: 2011-05-12 10:13:01 -0500 (Thu, 12 May 2011)
New Revision: 4818
Modified:
MOAB/trunk/tools/ProgOptions.cpp
Log:
fix build error with clang compiler
Modified: MOAB/trunk/tools/ProgOptions.cpp
--- MOAB/trunk/tools/ProgOptions.cpp 2011-05-12 14:57:24 UTC (rev 4817)
+++ MOAB/trunk/tools/ProgOptions.cpp 2011-05-12 15:13:01 UTC (rev 4818)
@@ -23,7 +23,7 @@
INT_VECT
- template <typename T>
+ template <typename T> inline
static types get_type(){ return FLAG; } //specialized for other types at bottom of this file
@@ -58,6 +58,12 @@
friend class ProgOptions;
+template<> ProgOpt::types ProgOpt::get_type<void>(){ return FLAG; }
+template<> ProgOpt::types ProgOpt::get_type<int>(){ return INT; }
+template<> ProgOpt::types ProgOpt::get_type<double>(){ return REAL; }
+template<> ProgOpt::types ProgOpt::get_type<std::string>(){ return STRING; }
+template<> ProgOpt::types ProgOpt::get_type< std::vector<int> >(){ return INT_VECT; }
ProgOptions::ProgOptions( const std::string& helpstring ) :
expect_optional_args(false)
@@ -740,21 +746,20 @@
/* Ensure g++ instantiates the template types we expect to use,
and also specialize the ProgOpt::get_type function for each supported type */
-#define DECLARE_OPTION_TYPE(T, PO_TYPE) \
+#define DECLARE_OPTION_TYPE(T) \
template void ProgOptions::addOpt<T>( const std::string&, const std::string&, T*, int ); \
- template bool ProgOptions::getOpt<T>( const std::string&, T* ); \
- template<> ProgOpt::types ProgOpt::get_type<T>(){ return PO_TYPE; }
+ template bool ProgOptions::getOpt<T>( const std::string&, T* );
-#define DECLARE_VALUED_OPTION_TYPE(T, PO_TYPE) \
- DECLARE_OPTION_TYPE(T, PO_TYPE) \
+#define DECLARE_VALUED_OPTION_TYPE(T) \
+ DECLARE_OPTION_TYPE(T) \
template void ProgOptions::getOptAllArgs<T> (const std::string&, std::vector<T>& ); \
template void ProgOptions::addRequiredArg<T>( const std::string&, const std::string&, T*, int ); \
template void ProgOptions::addOptionalArgs<T>( unsigned, const std::string&, const std::string&, int ); \
template T ProgOptions::getReqArg<T>( const std::string& ); \
template void ProgOptions::getArgs<T>( const std::string&, std::vector<T>& );
-DECLARE_OPTION_TYPE(void, ProgOpt::FLAG)
-DECLARE_VALUED_OPTION_TYPE(int, ProgOpt::INT)
-DECLARE_VALUED_OPTION_TYPE(double, ProgOpt::REAL)
-DECLARE_VALUED_OPTION_TYPE(std::string, ProgOpt::STRING)
