[MOAB-dev] r4815 - MOAB/trunk/src/parallel
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Wed May 11 16:27:05 CDT 2011
Author: kraftche
Date: 2011-05-11 16:27:05 -0500 (Wed, 11 May 2011)
New Revision: 4815
Modified:
   MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
   MOAB/trunk/src/parallel/WriteHDF5Parallel.hpp
Log:
small code cleanup in parallel hdf5 writer
Modified: MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp	2011-05-11 18:25:44 UTC (rev 4814)
+++ MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp	2011-05-11 21:27:05 UTC (rev 4815)
@@ -238,7 +238,71 @@
                                                const std::string& data )
   { list.push_back( Data(filter,data,filterval) ); }
+ErrorCode
+WriteHDF5Parallel::MultiProcSetTags::Data::get_sets( Interface* moab,
+                                                     Range& sets,
+                                                     Tag& id_tag ) const
+  ErrorCode rval;
+  int size;
+  const void* values[] = { 0, 0 };
+  Tag handles[2];
+    // Get first tag handle: this tag is used to filter sets
+    // (we only return sets for which this tag is set)
+  rval = moab->tag_get_handle( filterTag.c_str(), handles[0] );
+  if (MB_TAG_NOT_FOUND == rval)
+    return MB_SUCCESS; // return nothing if tag isn't defined on this proc
+  else if (MB_SUCCESS != rval)
+    return error(rval);
+    // Get data tag.  This tag contains IDs used to globally identify
+    // sets in the group with the filter_tag.  This might be the same
+    // tag as the filter tag.
+  rval = moab->tag_get_handle( dataTag.c_str(), handles[1] );
+  moab->tag_get_size( handles[1], size );
+  if (size != (int)sizeof(int)) {
+    fprintf(stderr, "Cannot use non-int tag data for matching remote sets.\n" );
+    assert(0);
+    return error(MB_FAILURE);
+    // We can optionally also filter on the value of the filter tag.
+    // (e.g. GEOM_DIMENSION)
+  if (useFilterValue) {
+    moab->tag_get_size( handles[0], size );
+      fprintf(stderr, "Cannot use non-int tag data for filtering remote sets.\n" );
