[MOAB-dev] r4791 - in MOAB/trunk: src src/io test/h5file test/parallel
kraftche at cae.wisc.edu
Mon May 2 17:07:51 CDT 2011
Author: kraftche
Date: 2011-05-02 17:07:51 -0500 (Mon, 02 May 2011)
New Revision: 4791
Modified:
MOAB/trunk/src/FileOptions.cpp
MOAB/trunk/src/FileOptions.hpp
MOAB/trunk/src/io/ReadHDF5.cpp
MOAB/trunk/src/io/ReadHDF5.hpp
MOAB/trunk/test/h5file/h5partial.cpp
MOAB/trunk/test/parallel/parallel_hdf5_test.cc
Log:
o Add FileOptions::get_toggle_option for options with yes/no/true/false values
o Change several #defines in ReadHDF5 to options controllable at runtime
o Add option to broadcast data rather than collectively read when reading
the same data on all procs in ReadHDF5
o Add unit tests to test HDF5 reader with the above optional behaviors enabled
Modified: MOAB/trunk/src/FileOptions.cpp
--- MOAB/trunk/src/FileOptions.cpp 2011-05-02 18:08:11 UTC (rev 4790)
+++ MOAB/trunk/src/FileOptions.cpp 2011-05-02 22:07:51 UTC (rev 4791)
@@ -346,7 +346,33 @@
return MB_FAILURE;
+ErrorCode FileOptions::get_toggle_option( const char* name,
+ bool default_value,
+ bool& value ) const
+ static const char* values[] = {
+ "true", "yes", "1", "on",
+ "false", "no", "0", "off",
+ 0 };
+ const int num_true = 4;
+ int index;
+ ErrorCode result = match_option( name, values, index );
+ if (result == MB_SUCCESS) {
+ value = index < num_true;
+ else if (result == MB_ENTITY_NOT_FOUND) {
+ value = default_value;
+ result = MB_SUCCESS;
+ else {
+ result = MB_TYPE_OUT_OF_RANGE;
+ return result;
bool FileOptions::compare( const char* name, const char* option )
while (!strempty(name) && toupper(*name) == toupper(*option)) {
Modified: MOAB/trunk/src/FileOptions.hpp
--- MOAB/trunk/src/FileOptions.hpp 2011-05-02 18:08:11 UTC (rev 4790)
+++ MOAB/trunk/src/FileOptions.hpp 2011-05-02 22:07:51 UTC (rev 4791)
@@ -59,6 +59,22 @@
ErrorCode get_null_option( const char* name ) const;
+ /**\brief Check for option with boolean (true/false, yes/no) value.
+ * Check for an option with a true/false value. Allowable values
