[MOAB-dev] question about OBB
Tim Tautges
tautges at mcs.anl.gov
Mon May 2 10:52:46 CDT 2011
Not sure about the deleting part, but you're right about the local creating part. Jason might be able to answer on
deletion...
- tim
On 05/02/2011 10:46 AM, Iulian Grindeanu wrote:
> Hello,
> Actually, I would like to have more control over the OBB tree creation/deletion or even update.
> When I am modifying geometry (or meshes), instead of deleting the whole tree, and creating it again, I would like to
> update "locally". Is that possible?
> So in the following scenario:
> I have a model with 200 surfaces. I would like to split one surface in 2, generate one more surface (and at least one edge)
> Can I modify the tree locally?
> It might be a too difficult job, and not worth the effort.
> There are methods to build a "tree" from a range of entities, and join after that with an existing tree,
> but I do not see any method to "delete" a tree (or a branch?)
> Or am I missing something?
> Thanks,
> Iulian
>> Hmm, maybe that third argument should be true so the OBB gets deleted
>> with the GTT? Or, there should be an argument to
>> the GTT constructor that passes through to that argument in OBBTree?
>> - tim
>> On 04/29/2011 05:19 PM, Iulian Grindeanu wrote:
>>> Hello,
>>> I have a question about OBB;
>>> When we use it in geom topo tool, the default constructor is called
>>> for obb:
>>> GeomTopoTool::GeomTopoTool(Interface *impl, bool find_geoments) :
>>> mdbImpl(impl), sense2Tag(0), senseNEntsTag(0),
>>> senseNSensesTag(0),
>>> geomTag(0), gidTag(0), obbTree(impl), contiguous(true),
>>> oneVolRootSet(0)
>>> This means that the obb sets are not deleted, even after
>>> GeomTopoTool is deleted. The third argument is by default false,
>>> (OrientedBoxTreeTool( Interface* i,
>>> const char* tag_name = 0,
>>> bool destroy_created_trees = false ))
>>> (if we would use obbTree(impl, 0, true), the OBB sets will be
>>> deleted when GeomTopoTool is deleted)
>>> Or is there another way to "clean" after the OBB?
>>> I am not quite sure about the lifecycle of OBB / and its sets
>>> Thanks,
>>> Iulian
>> "You will keep in perfect peace him whose mind is
>> steadfast, because he trusts in you." Isaiah 26:3
>> Tim Tautges Argonne National Laboratory
>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>> phone: (608) 263-8485 1500 Engineering Dr.
>> fax: (608) 263-4499 Madison, WI 53706
