[MOAB-dev] buildbot failure in moab-par: failed test
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Sat Apr 23 09:36:46 CDT 2011
Sorry about that, it was the mbfacet_test that hanged up.
I commented it out already.
What time is the checkout? Isn't it at 12:00 am sharp?
It looks that I committed the failing test before the checkout time.
Iulian
----- Original Message -----
> Fathom : moab-par build #490
> Results: failed test
> Buildslave: gnep
> Revision: None
> Reason: The Nightly scheduler named 'nightly' triggered this build Log
> Excerpt
> mv -f .deps/Test_MBMeshSet.Tpo .deps/Test_MBMeshSet.Po
> /bin/sh ../libtool --tag=CXX --mode=link mpicxx -Wall -pipe -pedantic
> -Wno-long-long -O2 -DNDEBUG
> -L/home/jvporter/packages/hdf5-x64-parallel/lib
> -L/home/jvporter/packages/hdf5-x64-parallel/lib -o mesh_set_test
> Test_MBMeshSet.o ../src/libMOAB.la -lm
> libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -O2
> -DNDEBUG -o mesh_set_test Test_MBMeshSet.o
> -L/home/jvporter/packages/hdf5-x64-parallel/lib ../src/.libs/libMOAB.a
> -lnetcdf /homes/jvporter/lib/libhdf5.a -lz -lm
> mpicxx -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel
> -I../src -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem
> -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION
> -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DUSE_MPI -DHDF5_FILE
> -DHDF5_PARALLEL -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=.
> -DMESHDIR=../MeshFiles/unittest -I../src -I../src
> -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map
> -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT CN.o -MD -MP -MF
> .deps/CN.Tpo -c -o CN.o `test -f '../src/CN.cpp' || echo
> './'`../src/CN.cpp
> mv -f .deps/CN.Tpo .deps/CN.Po
> -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT mbcn_test.o -MD
> -MP -MF .deps/mbcn_test.Tpo -c -o mbcn_test.o mbcn_test.cc
> mv -f .deps/mbcn_test.Tpo .deps/mbcn_test.Po
> -L/home/jvporter/packages/hdf5-x64-parallel/lib -o mbcn_test CN.o
> mbcn_test.o ../src/libMOAB.la -lm
> -DNDEBUG -o mbcn_test CN.o mbcn_test.o
> bsp_tree_poly_test.o -MD -MP -MF .deps/bsp_tree_poly_test.Tpo -c -o
> bsp_tree_poly_test.o bsp_tree_poly_test.cpp
> mv -f .deps/bsp_tree_poly_test.Tpo .deps/bsp_tree_poly_test.Po
> -L/home/jvporter/packages/hdf5-x64-parallel/lib -o bsp_tree_poly_test
> bsp_tree_poly_test.o ../src/libMOAB.la -lm
> -DNDEBUG -o bsp_tree_poly_test bsp_tree_poly_test.o
> -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT mbfacet_test.o
> -MD -MP -MF .deps/mbfacet_test.Tpo -c -o mbfacet_test.o
> mbfacet_test.cpp
> mv -f .deps/mbfacet_test.Tpo .deps/mbfacet_test.Po
> -L/home/jvporter/packages/hdf5-x64-parallel/lib -o mbfacet_test
> mbfacet_test.o ../src/libMOAB.la -lm
> -DNDEBUG -o mbfacet_test mbfacet_test.o
> -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT gttool_test.o
> -MD -MP -MF .deps/gttool_test.Tpo -c -o gttool_test.o gttool_test.cpp
> mv -f .deps/gttool_test.Tpo .deps/gttool_test.Po
> -L/home/jvporter/packages/hdf5-x64-parallel/lib -o gttool_test
> gttool_test.o ../src/libMOAB.la -lm
> -DNDEBUG -o gttool_test gttool_test.o
> -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT kd_tree_tool.o
> -MD -MP -MF .deps/kd_tree_tool.Tpo -c -o kd_tree_tool.o
> kd_tree_tool.cpp
> mv -f .deps/kd_tree_tool.Tpo .deps/kd_tree_tool.Po
> -L/home/jvporter/packages/hdf5-x64-parallel/lib -o kd_tree_tool
> kd_tree_tool.o ../src/libMOAB.la -lm
> -DNDEBUG -o kd_tree_tool kd_tree_tool.o
> -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT kd_tree_time.o
> -MD -MP -MF .deps/kd_tree_time.Tpo -c -o kd_tree_time.o
> kd_tree_time.cpp
> mv -f .deps/kd_tree_time.Tpo .deps/kd_tree_time.Po
> -L/home/jvporter/packages/hdf5-x64-parallel/lib -o kd_tree_time
> kd_tree_time.o ../src/libMOAB.la -lm
> -DNDEBUG -o kd_tree_time kd_tree_time.o
> ...make check-TESTS
> make[4]: Entering directory
> `/disks/itaps-buildslave/moab-par/build/test'
> make[5]: Entering directory
> [0;32mPASS[m: moab_test
> [0;32mPASS[m: homxform_test
> [0;32mPASS[m: scdseq_test
> [0;32mPASS[m: test_adj
> [0;32mPASS[m: seq_man_test
> [0;32mPASS[m: geom_util_test
> [0;32mPASS[m: xform_test
> [0;32mPASS[m: obb_test
> [0;32mPASS[m: adaptive_kd_tree_tests
> [0;32mPASS[m: bsp_tree_test
> [0;32mPASS[m: file_options_test
> [0;32mPASS[m: kd_tree_test
> [0;32mPASS[m: var_len_test
> [0;32mPASS[m: var_len_test_no_template
> [0;32mPASS[m: tag_test
> [0;32mPASS[m: mesh_set_test
> [0;32mPASS[m: mbcn_test
> [0;32mPASS[m: bsp_tree_poly_test
