[MOAB-dev] r4763 - MOAB/trunk/test
iulian at mcs.anl.gov
Thu Apr 21 09:34:12 CDT 2011
Author: iulian
Date: 2011-04-21 09:34:12 -0500 (Thu, 21 Apr 2011)
New Revision: 4763
Modified:
MOAB/trunk/test/gttool_test.cpp
MOAB/trunk/test/mbfacet_test.cpp
Log:
delete mesh before reloading a file for a test
only one moab instance is used now
Modified: MOAB/trunk/test/gttool_test.cpp
--- MOAB/trunk/test/gttool_test.cpp 2011-04-21 13:41:05 UTC (rev 4762)
+++ MOAB/trunk/test/gttool_test.cpp 2011-04-21 14:34:12 UTC (rev 4763)
@@ -99,7 +99,7 @@
std::cout << "\n";
std::cout << "create shell test: ";
- rval = create_shell_test( mb); // just pass the root set
+ rval = create_shell_test( mb);
handle_error_code(rval, number_tests_failed, number_tests_successful);
std::cout << "\n";
@@ -404,11 +404,12 @@
rval = mb->write_mesh(ofile2.c_str());
assert(MB_SUCCESS==rval);
+ rval = mb->delete_mesh();
+ assert(MB_SUCCESS==rval);
// now test loading it up
- Core mbcore2;
- Interface * mb2 = &mbcore2;
- rval = mb2->load_file(ofile2.c_str());
+ rval = mb->load_file(ofile2.c_str());
if (remove_output_file)
@@ -417,9 +418,9 @@
// do some tests on geometry
- moab::GeomTopoTool gTopoTool2(mb2, true);// to find the geomsets
+ // it would be good to have a method on updating the geom topo tool
+ // so we do not have to create another one
+ moab::GeomTopoTool gTopoTool2(mb, true);// to find the geomsets
Range ranges[4];
rval = gTopoTool2.find_geomsets(ranges);
Modified: MOAB/trunk/test/mbfacet_test.cpp
--- MOAB/trunk/test/mbfacet_test.cpp 2011-04-21 13:41:05 UTC (rev 4762)
+++ MOAB/trunk/test/mbfacet_test.cpp 2011-04-21 14:34:12 UTC (rev 4763)
@@ -60,7 +60,7 @@
ErrorCode normals_test(FBEngine * pFacet);
ErrorCode ray_test(FBEngine * pFacet);
ErrorCode split_test(Interface * mb, FBEngine * pFacet);
