[MOAB-dev] r4728 - in MOAB/trunk: src/moab src/parallel src/parallel/moab test/parallel
tautges at mcs.anl.gov
Fri Apr 8 17:27:07 CDT 2011
Author: tautges
Date: 2011-04-08 17:27:06 -0500 (Fri, 08 Apr 2011)
New Revision: 4728
Modified:
MOAB/trunk/src/moab/ScdInterface.hpp
MOAB/trunk/src/parallel/ParallelMergeMesh.cpp
MOAB/trunk/src/parallel/moab/ParallelMergeMesh.hpp
MOAB/trunk/test/parallel/parmerge.cpp
Log:
Update on parallel mesh merge. I've verified it works for simple cases.
In ScdInterface, just correcting a comment.
Modified: MOAB/trunk/src/moab/ScdInterface.hpp
--- MOAB/trunk/src/moab/ScdInterface.hpp 2011-04-07 17:28:02 UTC (rev 4727)
+++ MOAB/trunk/src/moab/ScdInterface.hpp 2011-04-08 22:27:06 UTC (rev 4728)
@@ -44,7 +44,7 @@
* Structured mesh blocks are returned in the form of ScdBox class objects. Each ScdBox instance
* represents a rectangular block of vertices and possibly elements (edges, quads, or hexes). The
- * entity handles for a ScdBox are guaranteed to be contiguous, starting at a starting valuable
+ * entity handles for a ScdBox are guaranteed to be contiguous, starting at a starting value
* which is also available through the ScdBox class. However, vertex handles may or may not be
* contiguous, depending on the construction method. The start vertex handle is also available from
* the ScdBox class.
Modified: MOAB/trunk/src/parallel/ParallelMergeMesh.cpp
--- MOAB/trunk/src/parallel/ParallelMergeMesh.cpp 2011-04-07 17:28:02 UTC (rev 4727)
+++ MOAB/trunk/src/parallel/ParallelMergeMesh.cpp 2011-04-08 22:27:06 UTC (rev 4728)
@@ -6,6 +6,7 @@
#include "moab/Skinner.hpp"
#include "moab/MergeMesh.hpp"
#include "moab/ParallelComm.hpp"
+#include "moab/CN.hpp"
extern "C"
@@ -52,7 +53,8 @@
//Merge Mesh Locally
MergeMesh merger(mb);
merger.merge_entities(ents,myEps);
- if(rval != MB_SUCCESS){
+ //We can return if there is only 1 proc
+ if(rval != MB_SUCCESS || myPcomm->size() == 1){
return rval;
@@ -65,46 +67,55 @@
/*3)Get Skin
-Get Range of 0 dimensional entities*/
- Range skinents;
+ //Look into improving by using higher skin
+ std::vector<Range> skin_ents(4);
Skinner skinner(mb);
- rval = skinner.find_skin(ents,0,skinents);
- return rval;
+ for(int skin_dim = dim; skin_dim >= 0; skin_dim--){
+ rval = skinner.find_skin(ents,skin_dim,skin_ents[skin_dim]);
+ if(rval != MB_SUCCESS){
+ return rval;
