[MOAB-dev] r4718 - MOAB/trunk/src
iulian at mcs.anl.gov
Wed Apr 6 11:46:02 CDT 2011
Author: iulian
Date: 2011-04-06 11:46:02 -0500 (Wed, 06 Apr 2011)
New Revision: 4718
Modified:
MOAB/trunk/src/SmoothFace.cpp
MOAB/trunk/src/SmoothFace.hpp
Log:
small clean up, remove (leftover) loops code.
Modified: MOAB/trunk/src/SmoothFace.cpp
--- MOAB/trunk/src/SmoothFace.cpp 2011-04-06 16:34:36 UTC (rev 4717)
+++ MOAB/trunk/src/SmoothFace.cpp 2011-04-06 16:46:02 UTC (rev 4718)
@@ -40,19 +40,6 @@
return nbInSet;
-ErrorCode getFaceSenseFromList(EntityHandle face,
- std::vector<EntityHandle> & faces, std::vector<int> & senses, int & sense)
- for (size_t i = 0; i < faces.size(); i++)
- if (face == faces[i])
- sense = senses[i];
- return MB_SUCCESS;
- return MB_FAILURE;// face not found in list
bool debug_surf_eval1 = false;
SmoothFace::SmoothFace(Interface * mb, EntityHandle surface_set,
@@ -1919,182 +1906,6 @@
return rval;
-// this will create the loops of geo set edges, based on connectivity
-// one external loop and possibly internal loops
-ErrorCode SmoothFace::find_loops()
- // this is purely a mesh/topology operation, probably should be part of GeomTopoTool()
- // the logic is to get all the sets of geo tag 1, children of the face set, and arrange them in loops
- /* std::vector<EntityHandle> _loops; // set1, set 3, set 5, ...
- std::vector<char> senses; // 0 forward, 1 backward: 0, 0, 1, ...
- std::vector<int> _loopEnds;// the first loop starts at 0 always;
- // first, get all the sets of dimension 1 from the _mb
- Tag geom_tag;
- ErrorCode rval = _mb->tag_get_handle(GEOM_DIMENSION_TAG_NAME, geom_tag);
- if (MB_SUCCESS != rval)
- return rval;
- // dimension 1 are curves
- Range csets;
- /*int dim=1;
- void *dim_ptr = &dim;
- csets.clear();
- rval = _mb->get_entities_by_type_and_tag(_set, MBENTITYSET,
