[MOAB-dev] r4713 - MOAB/trunk/itaps/igeom
iulian at mcs.anl.gov
Mon Apr 4 16:43:38 CDT 2011
Author: iulian
Date: 2011-04-04 16:43:38 -0500 (Mon, 04 Apr 2011)
New Revision: 4713
Modified:
MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp
Log:
sense convention changed, so this has to change too
(similar change to FBEngine)
Modified: MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp
--- MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp 2011-04-03 03:55:42 UTC (rev 4712)
+++ MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp 2011-04-04 21:43:38 UTC (rev 4713)
@@ -1322,39 +1322,18 @@
ErrorCode rval = _my_geomTopoTool->get_senses( MBH_cast(edge), faces, senses);
MBERRORR("Failed to get edge senses in iGeom_getEgFcSense.");
- int index = -1;
- EntityHandle mbfaceSet = MBH_cast(face);
- bool sense_forward = false;
- bool sense_reverse = false;
- for (unsigned int i = 0; i<faces.size(); i++)
- if (faces[i] == mbfaceSet)
+ EntityHandle mbface = MBH_cast(face);
+ for (unsigned int i = 0; i < faces.size(); i++)
+ if (faces[i] == mbface)
- index = i;
- if (senses[i]==0)
- sense_forward =true;
- else
- sense_reverse = true;
+ *sense_out = senses[i];
+ RETURN(iBase_SUCCESS);
- if (index == -1)
- *err = iBase_FAILURE;
- return;
+ *err = iBase_FAILURE;
+ return;
- // 0 is not possible for us, but maybe we should consider this?
- if (sense_forward && sense_reverse)
- *sense_out = 0; // is it really possible for a nice geometry ?
- else
- if (sense_forward) // only sense forward
- *sense_out = 1;
- else if (sense_reverse)
- *sense_out = -1;
- RETURN(iBase_SUCCESS);
