[MOAB-dev] r4645 - in MOAB/trunk: examples src src/moab tools
Tim Tautges
tautges at mcs.anl.gov
Thu Mar 31 16:56:46 CDT 2011
Not yet, it's on my list of things to do.
- tim
On 03/31/2011 03:50 PM, Hong-Jun Kim wrote:
> Can I ask if this problem is solved now for MeshKit test files?
> I am trying to debug current MeshKit error caused by failing to find geometry dimension tag of meshset.
> After fixing it, I have some errors returning "MB_MULTIPLE_ENTITIES_FOUND" for setting sense tag.
> I'd like to know if I have to wait until it is fixed or does anybody including me have to fix it?
> Thanks.
> Hong-Jun
>> From: iulian at mcs.anl.gov
>> To: moab-dev at mcs.anl.gov
>> Sent: Friday, March 25, 2011 10:54:42 AM
>> Subject: [MOAB-dev] r4645 - in MOAB/trunk: examples src src/moab tools
>> Author: iulian
>> Date: 2011-03-25 10:54:42 -0500 (Fri, 25 Mar 2011)
>> New Revision: 4645
>> Modified:
>> MOAB/trunk/examples/GeomSetHierarchy.cpp
>> MOAB/trunk/src/GeomTopoTool.cpp
>> MOAB/trunk/src/moab/GeomTopoTool.hpp
>> MOAB/trunk/src/moab/Types.hpp
>> MOAB/trunk/tools/gsets.cc
>> Log:
>> sense tags modifications; some cleanup required
>> meshkit tests do not pass now (test_scdmesh,
>> test_copygeom,
>> FAIL: test_triadvance
>> FAIL: test_mbgeom
>> FAIL: test_paver
>> FAIL: test_tetmesher
>> Old methods for senses are commented out, they will be completely
>> removed
>> Modified: MOAB/trunk/examples/GeomSetHierarchy.cpp
>> --- MOAB/trunk/examples/GeomSetHierarchy.cpp 2011-03-25 13:59:51 UTC
>> (rev 4644)
>> +++ MOAB/trunk/examples/GeomSetHierarchy.cpp 2011-03-25 15:54:42 UTC
>> (rev 4645)
>> @@ -28,7 +28,7 @@
>> std::vector<int> senses, pgids;
>> int dim, pgid, chgid;
>> void *dim_ptr =&dim;
>> - bool sense;
>> + int sense;
>> moab::GeomTopoTool gt(mb, true);
>> @@ -59,7 +59,7 @@
>> if (moab::MB_SUCCESS != rval) continue;
>> std::cout<< ent_names[dim+1]<< " "<< pgid<< ","
>> << ent_names[dim]<< " "<< chgid<< " sense is: ";
>> - if (sense) std::cout<< "FORWARD"<< std::endl;
>> + if (1==sense) std::cout<< "FORWARD"<< std::endl;
>> else std::cout<< "REVERSE"<< std::endl;
>> @@ -72,9 +72,9 @@
>> rval = mb->tag_get_data(gid_tag,&sense_ents[i], 1,&pgid);
>> - if (1 == senses[i]) std::cout<< "REVERSED"<< std::endl;
>> - else if (0 == senses[i]) std::cout<< "FORWARD"<< std::endl;
>> - else if (-1 == senses[i]) std::cout<< "UNKNOWN"<< std::endl;
>> + if (-1 == senses[i]) std::cout<< "REVERSED"<< std::endl;
>> + else if (0 == senses[i]) std::cout<< "BOTH"<< std::endl;
>> + else if (1 == senses[i]) std::cout<< "FORWARD"<< std::endl;
>> else std::cout<< "(invalid)"<< std::endl;
>> Modified: MOAB/trunk/src/GeomTopoTool.cpp
>> --- MOAB/trunk/src/GeomTopoTool.cpp 2011-03-25 13:59:51 UTC (rev 4644)
>> +++ MOAB/trunk/src/GeomTopoTool.cpp 2011-03-25 15:54:42 UTC (rev 4645)
>> @@ -31,546 +31,832 @@
>> // forward and reverse volumes, respectively. If a surface
>> // is non-manifold in a single volume, the same volume will
>> // be listed for both the forward and reverse slots.
>> - const char GEOM_SENSE_2_TAG_NAME[] = "GEOM_SENSE_2";
>> +const char GEOM_SENSE_2_TAG_NAME[] = "GEOM_SENSE_2";
>> - const char GEOM_SENSE_N_ENTS_TAG_NAME[] = "GEOM_SENSE_N_ENTS";
>> - const char GEOM_SENSE_N_SENSES_TAG_NAME[] = "GEOM_SENSE_N_SENSES";
>> +const char GEOM_SENSE_N_ENTS_TAG_NAME[] = "GEOM_SENSE_N_ENTS";
>> +const char GEOM_SENSE_N_SENSES_TAG_NAME[] = "GEOM_SENSE_N_SENSES";
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
