[MOAB-dev] r4703 - MOAB/trunk/src/moab
kraftche at cae.wisc.edu
Thu Mar 31 15:06:16 CDT 2011
Author: kraftche
Date: 2011-03-31 15:06:16 -0500 (Thu, 31 Mar 2011)
New Revision: 4703
Modified:
MOAB/trunk/src/moab/Types.hpp
Log:
Fix previous checkin of string arrays for enums: they are not available to C code
If Types.hpp is included in C (not C++) code the declarations appear in the
global namespace rather than the 'moab' one. However, the actual array
implementations in Types.cpp are always in the 'moab' namespace. So C code
trying to use them will encounter link errors. Wrap the array declarations
in Types.hpp in "#ifdef __cpluscplus" so it is obvious at compile time that
they will not be available to C code.
Modified: MOAB/trunk/src/moab/Types.hpp
--- MOAB/trunk/src/moab/Types.hpp 2011-03-31 19:58:10 UTC (rev 4702)
+++ MOAB/trunk/src/moab/Types.hpp 2011-03-31 20:06:16 UTC (rev 4703)
@@ -49,7 +49,9 @@
MB_STRUCTURED_MESH,
MB_FAILURE};
+#ifdef __cplusplus
extern const char* const ErrorCodeStr[];
+#endif
/** Misc. integer constants, declared in enum for portability */
enum Constants {
@@ -83,7 +85,9 @@
MB_MAX_DATA_TYPE = MB_TYPE_HANDLE
+#ifdef __cplusplus
extern const char* const DataTypeStr[];
+#endif
/** Used to reference tags; since they're so different from entities, we
* use void** instead of a uint to prevent them from being confused as
@@ -108,7 +112,9 @@
SENSE_FORWARD = 1 /**< forward */
+#ifdef __cplusplus
extern const char* const* const SenseTypeStr;
+#endif
#ifdef __cplusplus
} /* namespace moab */
