[MOAB-dev] r4694 - MOAB/trunk
jvporter at wisc.edu
Wed Mar 30 17:45:32 CDT 2011
Author: jvporter
Date: 2011-03-30 17:45:32 -0500 (Wed, 30 Mar 2011)
New Revision: 4694
Modified:
MOAB/trunk/RELEASE_NOTES
Log:
Fix release notes
Modified: MOAB/trunk/RELEASE_NOTES
--- MOAB/trunk/RELEASE_NOTES 2011-03-30 22:44:21 UTC (rev 4693)
+++ MOAB/trunk/RELEASE_NOTES 2011-03-30 22:45:32 UTC (rev 4694)
@@ -1,12 +1,14 @@
-Version 4.0.1:
+Version 4.1: (in progress)
* Structured mesh API (see src/moab/ScdInterface.hpp)
* Parallel read of netcdf-based .nc files using pnetcdf (see doc/metadata_info.pdf)
-* Compatible with iMesh 1.2 (see README.IMESH for details on compliance testing)
* Updated ParaView plugin (see tools/vtkMOABReader/README for details)
* Direct access to dense tag storage (see tag_iterate function in src/moab/Interface.hpp)
* Fix zoltan build on case-insensitive file systems (e.g. MacOS)
* Fix netcdf build w/ required HDF5 in non-system path
+Version 4.0.1:
+* Compatible with iMesh 1.2 (see README.IMESH for details on compliance testing)
Version 4.0:
* Many improvements to parallel correctness and efficiency
* Use of MPIO for parallel read of HDF5-based file format
