[MOAB-dev] r4691 - MOAB/branches/Version4.0
    jvporter at wisc.edu
    Wed Mar 30 17:40:41 CDT 2011
Author: jvporter
Date: 2011-03-30 17:40:41 -0500 (Wed, 30 Mar 2011)
New Revision: 4691
Modified:
   MOAB/branches/Version4.0/RELEASE_NOTES
Log:
Fix release notes
Modified: MOAB/branches/Version4.0/RELEASE_NOTES
--- MOAB/branches/Version4.0/RELEASE_NOTES	2011-03-30 21:08:10 UTC (rev 4690)
+++ MOAB/branches/Version4.0/RELEASE_NOTES	2011-03-30 22:40:41 UTC (rev 4691)
@@ -1,11 +1,5 @@
 Version 4.0.1:
-* Structured mesh API (see src/moab/ScdInterface.hpp)
-* Parallel read of netcdf-based .nc files using pnetcdf (see doc/metadata_info.pdf)
 * Compatible with iMesh 1.2 (see README.IMESH for details on compliance testing)
-* Updated ParaView plugin (see tools/vtkMOABReader/README for details)
-* Direct access to dense tag storage (see tag_iterate function in src/moab/Interface.hpp)
-* Fix zoltan build on case-insensitive file systems (e.g. MacOS)
-* Fix netcdf build w/ required HDF5 in non-system path
 Version 4.0:
 * Many improvements to parallel correctness and efficiency
