[MOAB-dev] r4688 - MOAB/trunk/src/io
kraftche at cae.wisc.edu
Wed Mar 30 09:20:30 CDT 2011
Author: kraftche
Date: 2011-03-30 09:20:30 -0500 (Wed, 30 Mar 2011)
New Revision: 4688
Modified:
MOAB/trunk/src/io/ReadHDF5.cpp
Log:
fix potential deadlock during parallel read of h5m file (and add more debuggnig output)
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2011-03-29 18:57:27 UTC (rev 4687)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2011-03-30 14:20:30 UTC (rev 4688)
@@ -2064,10 +2064,12 @@
// First collectively read all meta data
// use offset buffer as temporary storage to read set flags
- mhdf_Status status;
- const long num_sets = fileInfo->sets.count;
const size_t meta_size = H5Tget_size( meta_type );
const size_t content_size = H5Tget_size( content_type );
+ const long num_sets = fileInfo->sets.count;
+ dbgOut.printf( 2, "Searching contents of %ld sets (using buffer of size %ld)\n",
+ num_sets, num_sets * std::max( meta_size, sizeof(long) ) );
+ mhdf_Status status;
std::vector<unsigned char> offset_mem( num_sets * std::max( meta_size, sizeof(long) ));
long* const offset_buffer = reinterpret_cast<long*>(&offset_mem[0]);
mhdf_readSetFlagsWithOpt( meta_handle, 0, num_sets, meta_type, offset_buffer, collIO, &status );
@@ -2094,21 +2096,21 @@
Range::iterator hint = file_ids.begin();
long prev_idx = -1;
int mm = 0;
- dbgOut.printf( 3, "Searching set content\n" );
long sets_offset = 0;
while (sets_offset < num_sets) {
long sets_count = std::lower_bound( offset_buffer + sets_offset,
offset_buffer + num_sets,
content_len + prev_idx
) - offset_buffer - sets_offset;
+ assert(sets_count >= 0 && sets_offset + sets_count <= num_sets);
if (!sets_count) { // contents of single set don't fit in buffer
long content_remaining = offset_buffer[sets_offset] - prev_idx;
long content_offset = prev_idx+1;
while (content_remaining) {
- dbgOut.printf( 3, "Reading chunk %d of set contents table\n", ++mm);
long content_count = content_len < content_remaining ?
2*(content_len/2) : content_remaining;
assert_range( content_buffer, content_count );
+ dbgOut.printf( 3, "Reading chunk %d (%ld values) from set contents table\n", ++mm, content_count);
mhdf_readSetDataWithOpt( contents_handle, content_offset,
content_count, content_type,
content_buffer, collIO, &status );
@@ -2119,7 +2121,8 @@
content_buffer, content_count, idMap )) {
long id = fileInfo->sets.start_id + sets_offset;
hint = file_ids.insert( hint, id, id );
- break;
+ if (!nativeParallel) // don't stop if doing READ_PART because we need to read collectively
+ break;
