[MOAB-dev] r4684 - MOAB/branches/Version4.0
jvporter at wisc.edu
Tue Mar 29 13:55:09 CDT 2011
Author: jvporter
Date: 2011-03-29 13:55:09 -0500 (Tue, 29 Mar 2011)
New Revision: 4684
Modified:
MOAB/branches/Version4.0/
MOAB/branches/Version4.0/RELEASE_NOTES
Log:
Merge release notes
Property changes on: MOAB/branches/Version4.0
___________________________________________________________________
Modified: svn:mergeinfo
- /MOAB/trunk:4610-4611,4628,4631,4640-4641,4646,4663,4670,4672
+ /MOAB/tags/4.0.1RC2:4675
Modified: MOAB/branches/Version4.0/RELEASE_NOTES
--- MOAB/branches/Version4.0/RELEASE_NOTES 2011-03-29 18:49:00 UTC (rev 4683)
+++ MOAB/branches/Version4.0/RELEASE_NOTES 2011-03-29 18:55:09 UTC (rev 4684)
@@ -1,4 +1,9 @@
Version 4.0.1:
+* Structured mesh API (see src/moab/ScdInterface.hpp)
+* Parallel read of netcdf-based .nc files using pnetcdf (see doc/metadata_info.pdf)
+* Compatible with iMesh 1.2 (see README.IMESH for details on compliance testing)
+* Updated ParaView plugin (see tools/vtkMOABReader/README for details)
+* Direct access to dense tag storage (see tag_iterate function in src/moab/Interface.hpp)
* Fix zoltan build on case-insensitive file systems (e.g. MacOS)
* Fix netcdf build w/ required HDF5 in non-system path
