[MOAB-dev] r4661 - MOAB/trunk/itaps/imesh
jvporter at wisc.edu
Sat Mar 26 16:06:03 CDT 2011
Author: jvporter
Date: 2011-03-26 16:06:01 -0500 (Sat, 26 Mar 2011)
New Revision: 4661
Modified:
MOAB/trunk/itaps/imesh/iMesh_MOAB.hpp
Log:
Check allocated space before pointer value in array manager, since that's more
likely to be initialized (fixes a bunch of valgrind warnings in the nightly
iMesh tests)
Modified: MOAB/trunk/itaps/imesh/iMesh_MOAB.hpp
--- MOAB/trunk/itaps/imesh/iMesh_MOAB.hpp 2011-03-25 22:36:51 UTC (rev 4660)
+++ MOAB/trunk/itaps/imesh/iMesh_MOAB.hpp 2011-03-26 21:06:01 UTC (rev 4661)
@@ -132,7 +132,7 @@
int val_size,
int* err ) : arrayPtr(0)
- if (!*array_ptr || !array_allocated_space) {
+ if (!array_allocated_space || !*array_ptr) {
*array_ptr = std::malloc(val_size * count);
array_allocated_space = array_size = count;
if (!*array_ptr) {
