[MOAB-dev] r4654 - in MOAB/trunk: src src/io src/moab test test/perf
    kraftche at cae.wisc.edu
    Fri Mar 25 14:46:14 CDT 2011
Author: kraftche
Date: 2011-03-25 14:46:13 -0500 (Fri, 25 Mar 2011)
New Revision: 4654
Modified:
   MOAB/trunk/src/Core.cpp
   MOAB/trunk/src/io/ReadNC.cpp
   MOAB/trunk/src/moab/Core.hpp
   MOAB/trunk/src/moab/Interface.hpp
   MOAB/trunk/test/TagTest.cpp
   MOAB/trunk/test/perf/perftool.cpp
Log:
change tag_iterate function
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp	2011-03-25 19:40:47 UTC (rev 4653)
+++ MOAB/trunk/src/Core.cpp	2011-03-25 19:46:13 UTC (rev 4654)
@@ -2150,12 +2150,17 @@
 ErrorCode Core::tag_iterate( Tag tag_handle,
-                             Range::iterator& iter,
-                             const Range::iterator& end,
+                             Range::const_iterator iter,
+                             Range::const_iterator end,
+                             int& count,
                              void*& data_ptr )
+  Range::const_iterator init = iter;
   assert(valid_tag_handle( tag_handle ));
-  return tag_handle->tag_iterate( sequenceManager, iter, end, data_ptr );
+  ErrorCode result = tag_handle->tag_iterate( sequenceManager, iter, end, data_ptr );
+  if (MB_SUCCESS == result)
+    count = iter - init;
+  return result;
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp	2011-03-25 19:40:47 UTC (rev 4653)
+++ MOAB/trunk/src/io/ReadNC.cpp	2011-03-25 19:46:13 UTC (rev 4654)
@@ -260,11 +260,12 @@
   ERRORR(rval, "Couldn't add new vertices to file set.");
     // get a ptr to global id memory
-  Range::iterator viter = tmp_range.begin();
   void *data;
-  rval = mbImpl->tag_iterate(mGlobalIdTag, viter, tmp_range.end(), data);
+  int count;
+  rval = mbImpl->tag_iterate(mGlobalIdTag, tmp_range.begin(), tmp_range.end(), count, data);
   if (MB_SUCCESS != rval) mbImpl->release_interface(scdi);
   ERRORR(rval, "Failed to get tag iterator.");
+  assert((unsigned)count == tmp_range.size());
   int *gid_data = (int*)data;
     // set the vertex coordinates
@@ -466,11 +467,11 @@
          verts.psize() == 1);
     // get ptr to tag space
-  Range::iterator viter = verts.begin();
   void *data;
