[MOAB-dev] r4648 - MOAB/trunk/config
tautges at mcs.anl.gov
Fri Mar 25 12:47:36 CDT 2011
Author: tautges
Date: 2011-03-25 12:47:36 -0500 (Fri, 25 Mar 2011)
New Revision: 4648
Modified:
MOAB/trunk/config/ccmio.m4
Log:
Getting rid of configure warning when ccmio not found.
Modified: MOAB/trunk/config/ccmio.m4
--- MOAB/trunk/config/ccmio.m4 2011-03-25 16:38:29 UTC (rev 4647)
+++ MOAB/trunk/config/ccmio.m4 2011-03-25 17:47:36 UTC (rev 4648)
@@ -23,6 +23,8 @@
fi
# if CCMIO support is not disabled
+AC_MSG_CHECKING([if CCMIO support available])
+AC_MSG_RESULT([])
HAVE_CCMIO=no
if test "xno" != "x$CCMIO_ARG"; then
HAVE_CCMIO=yes
@@ -51,9 +53,9 @@
LDFLAGS="$CCMIO_LDFLAGS $LDFLAGS"
# Check for C library
- AC_CHECK_HEADERS( [ccmio.h], [], [AC_MSG_WARN([[Ccmio header not found.]]); HAVE_CCMIO=no] )
- AC_CHECK_HEADERS( [ccmioutility.h], [], [AC_MSG_WARN([[Ccmio header not found.]]); HAVE_CCMIO=no] )
- AC_CHECK_HEADERS( [ccmiocore.h], [], [AC_MSG_WARN([[Ccmio header not found.]]); HAVE_CCMIO=no] )
+ AC_CHECK_HEADERS( [ccmio.h], [], [HAVE_CCMIO=no] )
+ AC_CHECK_HEADERS( [ccmioutility.h], [], [HAVE_CCMIO=no] )
+ AC_CHECK_HEADERS( [ccmiocore.h], [], [HAVE_CCMIO=no] )
CPPFLAGS="$old_CPPFLAGS"
LDFLAGS="$old_LDFLAGS"
@@ -61,7 +63,8 @@
if test "x$CCMIO_ARG" != "x"; then
AC_MSG_ERROR("Ccmio not found or not working")
else
- AC_MSG_WARN("Ccmio support disabled")
+ AC_MSG_CHECKING([unsuccessful, Ccmio support disabled])
+ AC_MSG_RESULT([])
fi
CCMIO_CPPFLAGS=
CCMIO_LDFLAGS=
