[MOAB-dev] r4645 - in MOAB/trunk: examples src src/moab tools
iulian at mcs.anl.gov iulian at mcs.anl.gov
Fri Mar 25 10:54:42 CDT 2011
Author: iulian
Date: 2011-03-25 10:54:42 -0500 (Fri, 25 Mar 2011)
New Revision: 4645
Modified:
   MOAB/trunk/examples/GeomSetHierarchy.cpp
   MOAB/trunk/src/GeomTopoTool.cpp
   MOAB/trunk/src/moab/GeomTopoTool.hpp
   MOAB/trunk/src/moab/Types.hpp
   MOAB/trunk/tools/gsets.cc
Log:
sense tags modifications; some cleanup required
meshkit tests do not pass now (test_scdmesh,
test_copygeom,
FAIL: test_triadvance
FAIL: test_mbgeom
FAIL: test_paver
FAIL: test_tetmesher
Old methods for senses are commented out, they will be completely removed
Modified: MOAB/trunk/examples/GeomSetHierarchy.cpp
--- MOAB/trunk/examples/GeomSetHierarchy.cpp	2011-03-25 13:59:51 UTC (rev 4644)
+++ MOAB/trunk/examples/GeomSetHierarchy.cpp	2011-03-25 15:54:42 UTC (rev 4645)
@@ -28,7 +28,7 @@
   std::vector<int> senses, pgids;
   int dim, pgid, chgid;
   void *dim_ptr = &dim;
-  bool sense;
+  int sense;
   moab::GeomTopoTool gt(mb, true);
@@ -59,7 +59,7 @@
           if (moab::MB_SUCCESS != rval) continue;
           std::cout << ent_names[dim+1] << " "   << pgid << ", "
                     << ent_names[dim] << " " << chgid << " sense is: ";
-          if (sense) std::cout << "FORWARD" << std::endl;
+          if (1==sense) std::cout << "FORWARD" << std::endl;
           else std::cout << "REVERSE" << std::endl;
@@ -72,9 +72,9 @@
           rval = mb->tag_get_data(gid_tag, &sense_ents[i], 1, &pgid);
-          if (1 == senses[i]) std::cout << "REVERSED" << std::endl;
-          else if (0 == senses[i]) std::cout << "FORWARD" << std::endl;
-          else if (-1 == senses[i]) std::cout << "UNKNOWN" << std::endl;
+          if (-1 == senses[i]) std::cout << "REVERSED" << std::endl;
+          else if (0 == senses[i]) std::cout << "BOTH" << std::endl;
+          else if (1 == senses[i]) std::cout << "FORWARD" << std::endl;
           else std::cout << "(invalid)" << std::endl;
Modified: MOAB/trunk/src/GeomTopoTool.cpp
--- MOAB/trunk/src/GeomTopoTool.cpp	2011-03-25 13:59:51 UTC (rev 4644)
+++ MOAB/trunk/src/GeomTopoTool.cpp	2011-03-25 15:54:42 UTC (rev 4645)
@@ -31,546 +31,832 @@
 // forward and reverse volumes, respectively.  If a surface
 // is non-manifold in a single volume, the same volume will
 // be listed for both the forward and reverse slots.
-    const char GEOM_SENSE_2_TAG_NAME[] = "GEOM_SENSE_2";
+const char GEOM_SENSE_2_TAG_NAME[] = "GEOM_SENSE_2";
-    const char GEOM_SENSE_N_ENTS_TAG_NAME[] = "GEOM_SENSE_N_ENTS";
-    const char GEOM_SENSE_N_SENSES_TAG_NAME[] = "GEOM_SENSE_N_SENSES";
+const char GEOM_SENSE_N_ENTS_TAG_NAME[] = "GEOM_SENSE_N_ENTS";
+const char GEOM_SENSE_N_SENSES_TAG_NAME[] = "GEOM_SENSE_N_SENSES";
