[MOAB-dev] r4640 - MOAB/trunk/itaps/imesh
kraftche at cae.wisc.edu
Thu Mar 24 17:33:51 CDT 2011
Author: kraftche
Date: 2011-03-24 17:33:51 -0500 (Thu, 24 Mar 2011)
New Revision: 4640
Added:
MOAB/trunk/itaps/imesh/MBIter.hpp
Modified:
MOAB/trunk/itaps/imesh/Makefile.am
MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
MOAB/trunk/itaps/imesh/testc_cbind.c
Log:
Fix various deficiencies in iMesh iterator implementation:
o preserve order & duplicates when iterating over lists
o never return MBKINFE or MBENTITYSET from iterator queries
o add unit tests for iterator
Added: MOAB/trunk/itaps/imesh/MBIter.hpp
--- MOAB/trunk/itaps/imesh/MBIter.hpp (rev 0)
+++ MOAB/trunk/itaps/imesh/MBIter.hpp 2011-03-24 22:33:51 UTC (rev 4640)
@@ -0,0 +1,107 @@
+#ifndef MOAB_MB_ITER_HPP
+#define MOAB_MB_ITER_HPP
+#define IS_BUILDING_MB
+#include "Internals.hpp"
+#include "moab/Range.hpp"
+#include "moab/Core.hpp"
+#include <vector>
+#include <algorithm>
+class iBase_EntityArrIterator_Private
+ protected:
+ iBase_EntityType entType;
+ iMesh_EntityTopology entTopo;
+ EntityHandle entSet;
+ int arrSize;
+ public:
+ iBase_EntityArrIterator_Private( iBase_EntityType type,
+ iMesh_EntityTopology topology,
+ EntityHandle set,
+ int array_size )
+ : entType(type), entTopo(topology), entSet(set), arrSize(array_size)
+ virtual ~iBase_EntityArrIterator_Private() {};
+ int array_size() const { return arrSize; }
+ // NOTE: input array must be at least arrLen long
+ virtual void get_entities( Core* mb,
+ EntityHandle* array,
+ int& count_out ) = 0;
+ virtual ErrorCode reset( Interface* mb ) = 0;
+ class IsType {
+ private: EntityType type;
+ public: IsType( EntityType t ) : type(t) {}
+ bool operator()( EntityHandle h )
+ { return TYPE_FROM_HANDLE(h) == type; }
+ void remove_type( std::vector<EntityHandle>& vect, EntityType t ) {
+ vect.erase( std::remove_if( vect.begin(), vect.end(), IsType(t) ), vect.end() );
