[MOAB-dev] r4632 - in MOAB/trunk: src/io src/parallel src/parallel/moab test/parallel tools/vtkMOABReader
Rajeev Jain
jain at mcs.anl.gov
Thu Mar 24 02:09:17 CDT 2011
Hi Tim,
I'm unable to get the parallel version of ACIS based MeshKit running,
there is an error when running CoreGen (HongJun has the same thing, we are
trying to fix it.
....MeshKit-acis/rgg> coregen
Internal Error: invalid error code 1dc52e0 (Ring Index out of range) in
MPIR_Init_thread:394
p0_5954: p4_error: interrupt SIGSEGV: 11
my OCC based MeshKit works and I'll try to see how to parallel mergemesh fits
into CoreGen.
Is there an example for using ParallelMergeMesh?
Recently, I've found that saving and extrusion are the steps that eat a lot of
memory and take the most time.
I'm thinking of parallel save and extrusion?
Also, exploring pCAMAL in Cubit 12.2:
"The set parallel meshing works with the export parallel command to
generate a boundary mesh suitable for sweeping with the pCAMAL application."
Rajeev
P.S. Please let me know the correction/additions to the poster.
From: "tautges at mcs.anl.gov" <tautges at mcs.anl.gov>
To: moab-dev at mcs.anl.gov
Sent: Wednesday, March 23, 2011 13:58:18
Subject: [MOAB-dev] r4632 - in MOAB/trunk: src/io src/parallel src/parallel/moab
Author: tautges
Date: 2011-03-23 13:58:17 -0500 (Wed, 23 Mar 2011)
New Revision: 4632
Modified:
MOAB/trunk/src/io/ReadNC.cpp
MOAB/trunk/src/parallel/ParallelMergeMesh.cpp
MOAB/trunk/src/parallel/moab/ParallelMergeMesh.hpp
MOAB/trunk/test/parallel/parmerge.cpp
MOAB/trunk/tools/vtkMOABReader/vtkMOABReader.cxx
Log:
ParallelMergeMesh: updates from Nathan, now it works.
ReadNC: change method used to partition, so it checks available parameters
against # procs;
also partition over I first, then J, then K.
vtkMOABReader: handle tags on vertices differently, as data associated with
points instead
of with point cells.
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2011-03-22 05:39:07 UTC (rev 4631)
+++ MOAB/trunk/src/io/ReadNC.cpp 2011-03-23 18:58:17 UTC (rev 4632)
@@ -646,25 +646,39 @@
if (isParallel) {
// partition *the elements* over the parametric space; 1d partition for
now, in the k parameter
// (or j if there isn't one)
- if (-1 != klMin) {
- int dk = (kMax - kMin) / myPcomm->proc_config().proc_size();
- unsigned int extra = (kMax - kMin) % myPcomm->proc_config().proc_size();
- klMin = kMin + myPcomm->proc_config().proc_rank()*dk +
+ if (-1 != ilMin && (iMax - iMin) > myPcomm->proc_config().proc_size()) {
+ int di = (iMax - iMin) / myPcomm->proc_config().proc_size();
+ unsigned int extra = (iMax - iMin) % myPcomm->proc_config().proc_size();
+ ilMin = iMin + myPcomm->proc_config().proc_rank()*di +
std::min(myPcomm->proc_config().proc_rank(), extra);
- klMax = klMin + dk + (myPcomm->proc_config().proc_rank() < extra ? 1 :
0);
+ ilMax = ilMin + di + (myPcomm->proc_config().proc_rank() < extra ? 1 :
0);
- ilMin = iMin; ilMax = iMax;
+ klMin = kMin; klMax = kMax;
jlMin = jMin; jlMax = jMax;
- else {
+ else if (-1 != jlMin && (jMax - jMin) > myPcomm->proc_config().proc_size())
int dj = (jMax - jMin) / myPcomm->proc_config().proc_size();
unsigned int extra = (jMax - jMin) % myPcomm->proc_config().proc_size();
jlMin = jMin + myPcomm->proc_config().proc_rank()*dj +
jlMax = jlMin + dj + (myPcomm->proc_config().proc_rank() < extra ? 1 :
0);
+ else if (-1 != klMin && (kMax - kMin) > myPcomm->proc_config().proc_size())
+ int dk = (kMax - kMin) / myPcomm->proc_config().proc_size();
+ unsigned int extra = (kMax - kMin) % myPcomm->proc_config().proc_size();
+ klMin = kMin + myPcomm->proc_config().proc_rank()*dk +
+ std::min(myPcomm->proc_config().proc_rank(), extra);
+ klMax = klMin + dk + (myPcomm->proc_config().proc_rank() < extra ? 1 :
0);
+ jlMin = jMin; jlMax = jMax;
+ ilMin = iMin; ilMax = iMax;
+ else
+ ERRORR(MB_FAILURE, "Couldn't find a suitable partition.");
#endif
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110324/6881fdec/attachment.htm>
