[MOAB-dev] buildbot failure in moab-4.0-par: failed compile
James Porter jvporter at wisc.edu
Wed Mar 23 15:34:21 CDT 2011
People who paid really close attention to this error will notice that it
had a log of just the warnings, not the tail of the stdio for the build
step. That's fixed now.
- Jim
On Mon, 2011-03-21 at 00:35 -0500, moab-dev at mcs.anl.gov wrote:
> Fathom: moab-4.0-par build #6
> Results:
> failed compile
> Buildslave:
> gnep
> Revision:
> None
> Reason:
> The Nightly scheduler named
> 'nightly' triggered this build
> Log Excerpt
> minmax.h:29: warning: ‘rmax_3’ defined but not used
> minmax.h:29: warning: ‘rminmax_3’ defined but not used
> minmax.h:32: warning: ‘r1norm_1’ defined but not used
> minmax.h:33: warning: ‘r1norm_2’ defined but not used
> minmax.h:34: warning: ‘r1norm_3’ defined but not used
> minmax.h:36: warning: ‘r2norm_1’ defined but not used
> minmax.h:37: warning: ‘r2norm_2’ defined but not used
> minmax.h:38: warning: ‘r2norm_3’ defined but not used
> sort_imp.c:192: warning: initializer element is not computable at load time
> sort_imp.c:240: warning: initializer element is not computable at load time
> sort_imp.c:346: warning: ISO C forbids an empty translation unit
> WriteHDF5Parallel.cpp:827: warning: left-hand operand of comma has no effect
> WriteHDF5Parallel.cpp:869: warning: value computed is not used
> WriteHDF5Parallel.cpp:950: warning: value computed is not used
> WriteHDF5Parallel.cpp:1052: warning: value computed is not used
> WriteHDF5Parallel.cpp:1082: warning: value computed is not used
> WriteHDF5Parallel.cpp:1166: warning: value computed is not used
> WriteHDF5Parallel.cpp:1356: warning: statement has no effect
> WriteHDF5Parallel.cpp:1372: warning: statement has no effect
> WriteHDF5Parallel.cpp:1432: warning: value computed is not used
> WriteHDF5Parallel.cpp:1571: warning: statement has no effect
> WriteHDF5Parallel.cpp:1895: warning: value computed is not used
> WriteHDF5Parallel.cpp:74: warning: value computed is not used
> src/file.c:404: warning: ISO C90 forbids mixed declarations and code
> src/tags.c:567: warning: ISO C90 forbids mixed declarations and code
> src/tags.c:805:19: warning: C++ style comments are not allowed in ISO C90
> src/tags.c:805:19: warning: (this will be reported only once per input file)
> ReadSms.cpp:345: warning: ignoring return value of ‘int fscanf(FILE*, const char*, ...)’, declared with attribute warn_unused_result
> ReadSms.cpp:487: warning: ignoring return value of ‘int fscanf(FILE*, const char*, ...)’, declared with attribute warn_unused_result
> ReadSms.cpp:495: warning: ignoring return value of ‘int fscanf(FILE*, const char*, ...)’, declared with attribute warn_unused_result
> ReadSms.cpp:503: warning: ignoring return value of ‘int fscanf(FILE*, const char*, ...)’, declared with attribute warn_unused_result
> ReadHDF5.cpp:367: warning: format not a string literal and no format arguments
> WriteHDF5.cpp:478: warning: ‘init_time’ may be used uninitialized in this function
> WriteHDF5.cpp:478: warning: ‘gather_time’ may be used uninitialized in this function
> WriteHDF5.cpp:478: warning: ‘create_time’ may be used uninitialized in this function
> WriteHDF5.cpp:478: warning: ‘node_time’ may be used uninitialized in this function
> WriteHDF5.cpp:478: warning: ‘element_time’ may be used uninitialized in this function
> WriteHDF5.cpp:478: warning: ‘set_time’ may be used uninitialized in this function
> Core.cpp:171: warning: statement has no effect
