[MOAB-dev] r4619 - in MOAB/trunk: . config
kraftche at cae.wisc.edu
Mon Mar 21 14:16:35 CDT 2011
Author: kraftche
Date: 2011-03-21 14:16:35 -0500 (Mon, 21 Mar 2011)
New Revision: 4619
Modified:
MOAB/trunk/config/compiler.m4
MOAB/trunk/configure.ac
Log:
add simple checks that C++ compiler works because autoconf doesn't seem to check that if the compiler is specified by the user via CXX=
Modified: MOAB/trunk/config/compiler.m4
--- MOAB/trunk/config/compiler.m4 2011-03-21 19:15:38 UTC (rev 4618)
+++ MOAB/trunk/config/compiler.m4 2011-03-21 19:16:35 UTC (rev 4619)
@@ -10,6 +10,27 @@
+# Check if the C++ compiler works.
+# Arguments: action on success and action on failure
+AC_DEFUN([FATHOM_CHECK_CXX_WORKS], [
+ AC_LANG_PUSH([C++])
+ AC_MSG_CHECKING([if $CXX works])
+ AC_COMPILE_IFELSE(
+ [AC_LANG_PROGRAM( [class Cl { int i; public: Cl(int x) : i(x) {} };] [Cl x(5);])],
+ [AC_COMPILE_IFELSE(
+ [AC_LANG_PROGRAM( [],
+[#ifdef __cplusplus
+ choke me
+ #endif])],
+ [AC_MSG_RESULT([no (accepted invalid input)]); $2], [AC_MSG_RESULT([yes]); $1])],
+ [AC_MSG_RESULT([no (failed on trival valid C++ source)]); $2])
+ AC_LANG_POP([C++])
########## Helper function for FATHOM_CHECK_COMPILERS #############
# args: compiler variable, compiler list, path
AC_DEFUN([FATHOM_SET_MPI_COMPILER], [
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac 2011-03-21 19:15:38 UTC (rev 4618)
+++ MOAB/trunk/configure.ac 2011-03-21 19:16:35 UTC (rev 4619)
@@ -60,6 +60,7 @@
FATHOM_TEMPLATE_FUNC_SPECIALIZATION
AM_CPPFLAGS="$AM_CPPFLAGS $TEMPLATE_SPECIALIZATION $TEMPLATE_FUNC_SPECIALIZATION"
+FATHOM_CHECK_CXX_WORKS([], [AC_MSG_ERROR([Cannot build without C++ compiler])])
if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FC"; then
AC_FC_WRAPPERS
fi
