[MOAB-dev] [Itaps-dev] iMesh Test Summary 03/17/11
James Porter jvporter at wisc.edu
Thu Mar 17 18:38:53 CDT 2011
People paying close attention to the tests below will notice that MOAB
fails a bunch (and ultimately segfaults). I'm not sure about what's
causing the segfault yet, but the majority of the errors are due to MOAB
returning invalid error codes when given bad data. I have most of these
fixed already in a pending commit.
- Jim
On Thu, 2011-03-17 at 15:55 -0500, hill66 at llnl.gov wrote:
>      test
>     GRUMMP
>      MOAB
>      FMDB
>    RefImpl
> Implementation
> Tests - - - -
> download
> PASS
> PASS
> PASS
> PASS
> configure
> WARN
> WARN
> WARN
> PASS
> make
> WARN
> WARN
> PASS
> PASS
> make-install
> PASS
> PASS
> PASS
> PASS
> make-check
> PASS
> PASS
> PASS
> N/A
> iMesh UnitTest
> Tests - - - -
> configure
> PASS
> PASS
> PASS
> PASS
> make-spec-ck
> PASS
> PASS
> PASS
> PASS
> make-no-spec-ck
> DNR
> DNR
> DNR
> DNR
> run-save-load
> PASS
> FAIL
> FAIL
> PASS
> run-no-save-load
> PASS
> FAIL
> FAIL
> PASS
> run-valgrind
> PASS
> FAIL
> FAIL
> PASS
> Mesquite Tests
> configure
> PASS
> PASS
> PASS
> PASS
> make
> WARN
> PASS
> PASS
> PASS
> run
> WARN
> WARN
> WARN
> WARN
> Swapping Tests
> configure
> WARN
> WARN
> WARN
> WARN
> make
> PASS
> PASS
> PASS
> PASS
> run
> PASS
> FAIL
> DNR
> PASS
> For detailed test results see: UnitTest_summary.20110317.html
> Itaps-dev mailing list
> Itaps-dev at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/itaps-dev
