[MOAB-dev] r4604 - MOAB/trunk/src/io
kraftche at cae.wisc.edu
Thu Mar 17 09:07:57 CDT 2011
Author: kraftche
Date: 2011-03-17 09:07:52 -0500 (Thu, 17 Mar 2011)
New Revision: 4604
Modified:
MOAB/trunk/src/io/ReadHDF5.cpp
Log:
include some info about fragrmentation in debug output for HDF5 reader
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2011-03-16 22:18:01 UTC (rev 4603)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2011-03-17 14:07:52 UTC (rev 4604)
@@ -895,7 +895,7 @@
debug_barrier();
- dbgOut.tprint( 1, "READING NODE COORDINATES\n" );
+ dbgOut.tprintf( 1, "READING NODE COORDINATES (%lu nodes in %lu selects)\n", nodes.size(), nodes.psize() );
// Read node coordinates and create vertices in MOAB
// NOTE: This populates the RangeMap with node file ids,
@@ -1392,6 +1392,7 @@
CHECK_OPEN_HANDLES;
debug_barrier();
+ dbgOut.tprintf( 1, "READING %s CONNECTIVITY (%lu elems in %lu selects)\n", elems.handle, file_ids.size(), file_ids.psize() );
ErrorCode rval = MB_SUCCESS;
mhdf_Status status;
@@ -1613,6 +1614,9 @@
CHECK_OPEN_HANDLES;
+ debug_barrier();
+ dbgOut.tprintf( 1, "READING %s CONNECTIVITY (%lu elems in %lu selects)\n", fileInfo->elems[i].handle, elems_in.size(), elems_in.psize() );
EntityHandle* const buffer = reinterpret_cast<EntityHandle*>(dataBuffer);
const int node_per_elem = fileInfo->elems[i].desc.vals_per_ent;
const size_t buffer_size = bufferSize / (node_per_elem*sizeof(EntityHandle));
